B3150 v L3200 What Difference
2,925
Hi,
I am considering a new tractor and have been offered a B3150 by one dealer, and an L3200 by another dealer. Specs are similar. Is one a newer model than the other?
they are two different classifications of tractors, engine size might be close, but the L series should be a little more "heavy duty" - the L might not have MMM pto, just guessing WITHOUT looking at specs. They are different depending on what they are used for, what are you looking to do specifically?
9,844
Look at the rear end, The B will be lighter and smaller the L will be larger!
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
As far as I can tell the B3150 is not offered in the US. I saw the B3150 listed and then realized it was on a British website. We can choose between a B2650 and a B3350 in the new tractors in the 50 series. The 3350 has enough horsepower to require a dpf filter and some other smog emission devices, but the 2650 does not have the dpf filter. I would look closely at the emissions equipment on a 3150 and the engine type, and ask around before buying. The B3350 over here has had a lot of problems. The L's and the B2650 seem to be doing ok.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
The EPA doesnt have authority in Australia. Thats why you still have L3200s and a bastard B3150 that is a B3350 without the Smog hardware.
An L is larger framed, and heavier with more robust hydraulics. A B is smaller but typically has more nice features. A Grand L is typically bigger yet than a standard L, with stronger hydraulics than the standard L. An M is even bigger...
What are your intentions for the machine? Moving hay bales? Forget the B, doing mostly mowing, B would fit nice...
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum Jim. Glad you joined with us.
When I went to the dealer I was looking for a "B" series tractor. When I told my dealer what I was going to use it for, he said I wouldn't be happy with the "B" and recommended an "L" series. More than once I have thanked him for his recommendation. In fact, I wish I had gone with an even bigger "L" like a L4600.
It ALL depends on what you are using it for.
Jim Orman
Royalla,NSW, Australia
Hi All,
Thanks for the replies. Of course excellent question...what am I going to use it for?
1. Excavating for the slab for the new garage (12m x 7M)
2 Earthworks to address drainage issues on our 7 acre block
3. Grading and spreading gravel on the 300+ metre driveway.
No mowing...I have bought a GR212048-AU for that.
Regards (PS out for 6 days while moving to the block)
Jim
mickeyd
Mar 21, 2014
1,192
Guin, AL
Ditto on what Ryansweatt2004 said. You will be kicking yourself later if you don't.
Trekker
Buying tractor
Nov 17, 2021
Mittagong NSW Australia
I am on the horns of the exact same dilemma. Dealer seems keener to sell the L3800 rather than B3150.
As far as I can tell, availability may be an issue. There are readily available L3800’s but a 3-4 month wait for B3150.
From my research, the L is a larger, heavier tractor with a little more capability whereas the B3150 has more niceties on it.
For me, the most attractive feature of the L is the Quick Coupler on the loader bucket making change of front implements much simpler. The B has a pinned bucket.
Good luck,
