B2650 stop then no start.
DLHam
2017 B2650
Aug 9, 2023
Cincinnati Ohio
Bought new in 2017, first ever issue. Any suggestions on what I may have missed appreciated.
2017 Kubota B2650, 395 hours. Tractor started and mowed fine previous week.
-Started tractor in garage, let idle for a bit. Drove out across yard to start mowing.
-Once engine warmed and at 1200 rpm slid PTO lever forward.
-As PTO engaged, tractor shut off. Disengaged PTO and went to start tractor, no dash lit and no start.
-Found panel/OPC 5 watt fuse blown. Replaced and had dash again but no start. Towed (in neutral) back to garage.
-Found PTO selector safety switch top broke off, PTO engagement safety switch loose/wobbly so got two new switches. Checked and had 12.4 volts across tractor side of connectors to switch.
-Checked seat switch (working).
-Still no start.
-Went ahead and replaced and adjusted the HST Pedal safety as it was quite grungy.
-no start so pulled dash cowling and checked parking switch, it was OK and looked at wiring which appeared fine.
-At this point I put ignition to run and jumped starter and tractor started and all (including PTO) worked fine.
-so if I jump starter all works but not by key.
So is this pointing to bad starter relay?
Many thanks,
DLHam
2017 B2650
Aug 9, 2023
Cincinnati Ohio
DLHam
2017 B2650
Aug 9, 2023
Cincinnati Ohio
UPDATE 08/15/2023
My cousin came over and using his multimeter and other tools we verified:
- all inputs from safety switches were correct for start (HST pedal, park brake switch, PTO engagement).
- Verified key in run position, and verified start signal sent when placed into start position (past glo plug heat).
-verified all wires coming into OPC Timer controller had proper voltage.
- verified from OPC connector down to starter had continuity.
- no start still
-tested voltage at starter where blade connection from OPC timer controller, no voltage when key placed in starter position.
So, it appeared to possibly be OPC timer/controller module. Took it down to Kubota dealer; they said no way to test it but based on testing we did also thought OPC Timer. New one came in, and still no start.
Is there any other relay somewhere we may be missing?
If I use a remote starter switch between the 12V main and blade on relay, starter works fine.
So for some reason still not getting 12v down to starter for some reason?
Using a remote starter is an OK work around but would really want to figure this out.
9,302
It's a direct connection from the OPC to the starter solenoid.
nothing else between them.
So if you have power coming out of the OPC starter connection on start and no power at the starter you have a bad wire or connection.
Also make sure you have a good ground connection to the OPC.
DLHam
2017 B2650
Aug 9, 2023
Cincinnati Ohio
Yes, thats we saw and thought from schematic. We did verify continuity from wire at OPC down to starter blade, but also that the OPC is not sending a signal out , which is why we replaced OPC.
9,302
Did you check to see if it's getting all the right signals in?
Like a start signal from the switch?
Including a good ground to the OPC?
You don't need a fancy meter a simple test light will do it.
9,302
Looking at Kubota parts diagram I ran across a starter relay (which we have not touched); anyone know what this is doing?
It's glow plug or stop solenoid relay.
Neither of them has anything to do with it not cranking.
I guess you don't believe the schematic or me, there is no relay between the OPC and the starter!
DLHam
2017 B2650
Aug 9, 2023
Cincinnati Ohio
Yes, my cousin made a chart of all inputs by wire to OPC and we tested and verified all safety switch inputs, voltage in and ground.
I am still trying to find that starter relay on schematics.
9,302
I've said it three times, there is NO starter relay!
DLHam
2017 B2650
Aug 9, 2023
Cincinnati Ohio
I believe you, I am just puzzled that by the WSM all correct inputs from key switch and other safety switches are present and correct yet OPC timer/controller is not outputting voltage to starter per schematic. So puzzled what we are missing. As we had dash/seat off we examined all wiring and found no fraying or pinched wires. Swapping the OPC controller module didn’t fix.
By the WSM it should be cranking.
2,393
Post a picture of the schematic that shows the relay that concerns you. I don’t see anything that says “starter relay“ in the schematics above.
The “starter relay” may be the “solenoid” on the starter?
9,302
Yes I agree, But what does the relay do that Kubota has on their schematics online for B2650 that they call a starter relay ?
once I use remote starter switch tractor runs fine.
What online schematic are you looking at?
DLHam
2017 B2650
Aug 9, 2023
Cincinnati Ohio
It’s on the B2650 electric online diagrams. Pasting it here.
Its listed as part 060, part #RD451-54210 RELAY. Also what is confusing is in WSM under starter troubleshooting it says one possible reason for no crank is starter relay. Hence my confusion.
We verified all inputs on the switch engine start diagram (we even cycled switches to verify they were "on" or "off" as needed), PTO clutch lever switch "on" and HST pedal switch "on" . We got 12V from ignition (key) switch when in run position, got 12V on glo plug position from switch, and got the 12 V to energize starter from switch, but no signal from OPC timer out to starter. So replaced OPC timer but same result.
If I put my remote starter switch to blade on solenoid on starter and main battery line to it, it starts up fine so not starter/solenoid.
So now trying to figure what we may have overlooked. Abut ready to bypass OPC timer for starting position on key :-( (I hate electronics...)
9,302
Wanna know the answer to why your getting such conflicting info?
Drum Rolllllllll....
You're looking at the Wrong WSM!
That WSM is for EU units, throw it in the trash!
There is likely a huge difference in the USA WSM and EU WSM for the US models.
And that's not a schematic in the first pic that's a parts diagram, huge difference!
Look at the envelope top right of your screen.
DLHam
2017 B2650
Aug 9, 2023
Cincinnati Ohio
THANK YOU!!!
