Today I went to get on the 2150 it started right up and right away I noticed the tach not working. No movement from it at all , everything else is working, fuel gauge, temp gauge ,the start up and glow plug lights are all working properly just no movement from tach . Two days ago I replaced the power wire from starter to battery ,so thinking I may have pulled or loosened some wires or plugs . I rechecked them while I had the dash panel out I checked all the wireing conections I found the fuse end that had two 15 amp fuses in it checked them to find both fuses ok. I rechecked my power wire to starter from battery, everything looks to be in order, Now my question is the tach worked before I replaced the power wire from battery to starter .The only thing that I am not sure of is the black cable running from the back of the dash in the center of the tach and hour meter to something under the hood at the front right side of the engine this cable has screw on ends at both ends , is this for the tach or the hour meter. tractor info is as follows 89 b2150dt 4 cyl diesel, 4 wheel drive , power steering ,and front end loader Thanks for any help
