B211 loader subframe pics or description wanted.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
117
102
Lopez Island, WA
I have a new-to-me B5100 4wd tractor, and a small Kubota FEL - but the subframe doesn't quite fit on the tractor. Does anyone have any pictures (aside from the youtube video) of the B211 loader subframe that was optional on these little guys?
I'm going to fab up a new subframe that fits my tractor properly; the one I have is largely made from 2.5" x .5" steel bar and that looks pretty much like what's in the video afaict.
I've like to know how the B211 fastened to the rear diff; the loader I have looks a lot like a B219 according to pics I found in the B219 manual here:
http://www.kubotabooks.com/AutoIndex/index.php?dir=Loaders and buckets/.
Any pictures or descriptions appreciated; I don't want to break my tractor!
Thanks -
- Bart
9,725
Does this help you out?
The four holes that bolt #4 goes in bolts to the axle cases
The six holes for #6 bolt to the motor
Four more go to bracket #35 and the transmission
barts
Feb 10, 2015
117
102
Lopez Island, WA
Perfect! Thank you - exactly what I was looking fo!
Off to pick up some steel tomorrow :)
Thanks again -
- Bart
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum from Alabama. Please post pictures as you progress for all of us to learn.
barts
Feb 10, 2015
117
102
Lopez Island, WA
I'll post pictures; when I get started I'll start a new thread and add a reference to that thread to this one.
I'm also adding a hydraulic pump to the front of the tractor to drive the loader's 2" cylinders; the B211 loader that was for the B5100 used the built-in pump, but also had 1.5" cylinders so it moved almost twice as fast.
http://www.orangetractortalks.com/forums/showthread.php?t=17284&page=3 has the info on the hydraulics :).
- Bart
barts
Feb 10, 2015
117
102
Lopez Island, WA
Thanks for the manual tip.
I thought I'd post some pictures of the tractor and the FEL. Picked up some steel and started cutting today; need to lay out and drill some holes tomorrow.
I don't have much in the way of metric bolts, so Mcmaster is getting another order tomorrow :).
- Bart
OldeEnglish
Jul 13, 2014
766
Western, MA
Sweet tractor :D Looks like it's in nice shape!
How in the world does someone bend a bucket like that??:eek: Please let me know so that I don't ever do that! :confused:
barts
Feb 10, 2015
117
102
Lopez Island, WA
No idea... I'm working out how to straighten it; I don't think it matters much but it sure looks funky.
- Bart
OldeEnglish
Jul 13, 2014
766
Western, MA
It doesn't look like the edges are rolled/folded or have any reinforcement so it's probably fairly easy to do.... If you get that puppy straight I would weld some angle iron across the top to reinforce it... Good luck!
barts
Feb 10, 2015
117
102
Lopez Island, WA
Had a couple of days to spend on the Kubota... got the subframe welded and rattle canned.... a little overbuilt, but since I can still lift it and it doesn't have to fly, I'm happy.
Made it from about 7' of 3" x 1/2" flat bar, the original uneven leg angle, and some misc. 2" pipe and 3/8" plate for the rear mounts to the axle. I a ran a bunch of sticks of 7018 w/ DCEP at 125 amps... it's probably not going to break :).
Now for more paint on the bottom, and then time to bolt it up again. Next up comes the hydraulic pump mount and drive assembly. This will take a bit of machining... also need to replace all the hoses on the loader, and will change out all the 1/4" schedule 40 street ells on the cylinders to proper hydraulic fittings - they're cheap enough at surplus center, and one of the street ells is broken off in the cylinder as it is. Another hobby of mine is steam boats, and I have come to distrust screwed schedule 40 pipe for anything that could see any mechanical loading. Schedule 80 for everything that sees steam.
- Bart
7,190
Bart, nice work. You make it look simple with it all painted up, but I know it's a task to get all that iron square to the world and ALL the holes to match the tractor. Yep, you've got enough iron in it!
OldeEnglish
Jul 13, 2014
766
Western, MA
Nice job on the subframe, it looks great! Your absolutely right about SCH 40, 80 black pipe should always be used on hydraulics or steam. ST fittings are always prone to leaking and usually require Teflon to get them to hold pressure, which is a no no for hydraulics. If you have to make a tight turn with black fittings, make sure to use a space nipple and not a close nipple. A SCH 80 close nip is basically SCH 40 by the time the threads are cut in. Having a space nip gives a little more meat between the two threads on the nipple, thus making it stronger.
It doesn't take much force to shear off SCH 40 at the threads. Happens a lot with roof top gas piping when there is an excessive snow load that weighs down a flat roof. The roof will move enough to shear the pipe off at the threads.
barts
Feb 10, 2015
117
102
Lopez Island, WA
Got some more time in on the tractor. Welded up a front assembly to support the braces for the loader uprights and made new braces; I had to remove the original braces welded to the loader uprights since they hit the air cleaner and muffler on this tractor. I used rod ends because it made things simple.
I also gave up looking for that splined sprocket and used a Fenner 'B-Lok' shrink disc to clamp the drive adaptor I machined up onto the splined front of the crankshaft. This worked well, but the amount of shrink is pretty limited so tolerances are pretty tight - around .001" clearance is ideal.
I'm going to use dual Lovejoy couplings to drive the pump; there's no room for the chain drive sprocket approach since the sprocket is in front of the crank now instead of over it.
