B1550 help.
sandymac
9
By Glasgow
Hello to you all, i have just joined and need some help.
I have just bought a Kubota B1550 which looks great. But it has one small problem, namely the engine block is terminally cracked.
I did know this at least before buying.
What i need to know is what model of engine to look for to source a 2nd hand unit to swap with mine. I am in the UK. Hopefully the engine is used in other models and or applications???
Thanks, Sandy
8,366
The D750, D850, D950 are all the same bolt pattern and will interchange, but just use a D950 to replace and you'll be better off!
cb750k8
B7200HST D 4X4
Aug 23, 2013
101
Dublin, Ireland
HI
There should be a name plate on your tractor which should put you at ease as to what engine installed. Look on left side of tractor at your left foot as you sit on the seat.
If your "Glasgow" is in Scotland I bought a similar tractor of "Kubotajohn" in Alexandria which is near you. He may know of a suitable engine. If this is of intrest I can give you contact details.
Cheers
sandymac
9
By Glasgow
HI
Cheers
Hi, have sent you a message mate.
Sandy
hodge
Nov 19, 2010
2,938
501
Love, VA
Sandy
You also might want to connect with Rob here on the forum- he is in England, and is pretty savy on refits.
8,366
If you can post some pictures of your motor, I might be able to tell you how much work it will be to put it in.
That looks like the same setup type as my motor that I put into my B7100.
