Hi! I’m a new member of OrangeTractorTalks and of a L4600 Kubota tractor.
In the past I have only operated a Ford 8n so using telescoping stabilizer arms is new to me. I’m sure the issue I am having is operator head space and timing but I am having trouble with spread of the lift arms being wider them the pins on the implement I’m hooking up to. It seems that the telescoping stabilizer arms prevent the lift arms from opening wider. The stabilizer meet the limit to be shortened to allow the lift arms to open wider.
With an 8n I have been able to back up to an implement spread the lift arms as wide as needed with the only times I have had to move the implement was the when the lift arm would not reach, I was backed in crooked.
With the telescoping stabilizer when I back up aligned I have to move the implement to be able to get the lift arm ball on the pin of the implement for both sides.
What am I missing here? Any suggestions or advice will help. I hope I have explained my issue well enough to be understood.
