Add on Hydraulics?
KZ15
Kubota L3750DT
Jun 10, 2014
9
Highland, Kansas
Has anyone added on Hydraulics? I just got an old L3750DT. It just has two hydraulic hoses going to the FEL. I was looking for some advice on how difficult it is to add a set out the back so I can disk with this tractor.
5,124
There is a kit you could get to do just that, But they are usually very pricey.
It would be Kit L8411.
But you could very simply just add a longer line from the return of the loader spool valve to a new open center spool valve and then back to the hydraulic block.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
That pretty much says it.
My dealer charged me $500 for a 6' hose, 3/8" Dixon QD set, and an inline mounting bracket. I'm pretty sure he used the original return hose from the FEL bsck to the manifold for the return. Save yourself 3 or 4 hundred bucks.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
I added rear remotes to my L3000. Took the supply line for the loader and hooked it to the intake side if the remote valve. Came out of the remote back to the loader. When the remotes aren't in use the loader works as normal. Unless you have 3 hands you can't drive, work the loader and work the remotes at the same time so all is good.
I say do it yourself and save a few hundred.
