Recently purchased  a Kubota L2250 4wd d1302 engine.  Under cover, 1050 hours, 5' tiller, finish mower, post hole digger, brush hog, box blade for $5000.   Thought it was a good price for a quoted 'it is a good tractor'.
After replacing battery, started & run smooth, good power, no smoke.
Started to drive it home (about two miles). Gauge indicated it was above mid-line in temperature (did not boil), turned around, parked it, & started to check it for overheating cause. Also noticed power steering didn't appear to be working.
Found radiator plugged with dirt-dobber nests. Water pump bearing worn, massive corrosion of aluminum gear case cover & thermostat housing. Hydraulic pump with internal bushing & shaft broken. Exhaust manifold cracked. Found fuel pump was not pumping (just allowing gravity flow).
Replaced those with new & good used parts. Pulled the head & had it checked & (they rebuilt it, didn't check it).
Pulled 'drive shaft for front axle & axle pivots (corrosion starting). Drilled a tapped a couple of holes in pivots for grease zerts.
Put everything back together & it started & ran smooth, good power, no smoke. Noticed very slight 'knocking sound' at low rpm. Sound would go away at higher rpm's. Pulled injectors & had them tested. All failed, with slight 'dribbling' & 'popping off' too soon. Told to run with a diesel additive for injector cleaning for a few hours. Ran about five hours good power, but no change in sound.
Purchased & installed 3 new injectors. No change in sound. After running for about an hour longer, pulled oil pan, head, rods & pistons. Bearings showed no apparent wear but #2 cylinder's piston was slightly scuffed and rings would not move as they should. Cylinder wall was slightly scuffed.
Have been told it was most likely due to the injectors releasing too much fuel and washing the oil off of piston & cylinder wall. Also, possible diesel contamination of engine oil because of failed fuel pump.
My thinking is that even though your tractor is running good, it wouldn't hurt to check your fuel pump (see if it will suck diesel from a container on the floor & have the engine run okay).
Pull the injectors & have them checked for proper operation (shop near me checks them free). New injectors cost me about $300. Easy to install.
If you are 'gaining' oil, maybe your fuel pump is letting diesel into the crankcase & diluting the oil. New pump about $65.
Always keep your coolant system in top condition & check both sides of radiator for blockages. About $225 for radiator cleaning, water pump, new hoses, & thermostat.
My rebuild will cost $5000 if I let Kubota or other shops do all the work. If I do most of the labor it will cost about $2000 in parts & machine shop charges.
I've spent several days researching the engine failure & how to reduce chance of failure again.
So far planning on making inner cylinder (#2) about .0005 inches bigger than outer cylinders. (industrial Kubota engine supposedly has smaller piston)
Also having the new pistons coated by 'Calico, Swain-tech, or another 'reputable' company. Supposed to reduce friction, expansion due to heat, & cool piston better from engine oil.
Plan to do thorough cleaning of machine shop work & to use a finer hone than normal to reduce cylinder wear during 'break-in'. (apparently cross hatch pattern is worn off during break-in & more metal particles end up in the engine oil with more coarse hones).
