85-110 hp pre-emissions
2,741
Brother - welcome to the forum!
That question is really broad - you need to cut hay, bale hay? Move bales? Why so much HP?
Doing any mowing? If so - you have a 7' or bigger batwing? Need a cab? What $$$ amount you looking to spend?
I'm not trying to be a smartass - just define the question a little more and those that have those big machines will jump in ;)
I would imagine you will need to be in the larger "M" series
4,832
The question is way too broad and I will be a smartass - IH 1066.Hydro
Ohio farmer 39
Looking at kubota. 4x4, loader, open station. I need at least 80 hp pto for my equipment. Need to lift comfortably 1500 round bales.
SDT
multiple and various
Apr 15, 2018
3,266
1,062
SE, IN
M9540 sounds about right but a bit low for large windrows.
Also a bit light in the rear but OK if you load a bale on the three point before the FEL.
PTO brakes a bit weak so idle things down before disengaging PTO.
