5 ft Roto Tiller Operation
davesl708
BX2200, LA211, RCK60B-22BX, 5ft. Rototiller, Rear Blade, 4ft Drag Harrow
Feb 24, 2013
40
Shawnee, Kansas
I have a 5ft. rototiller powered from my BX2200 rear pto.
Does anyone know if there is a best rpm to operate a rototiller of this size.
I am breaking sod and want to know what rpm would be best for this size tiller.
Thanks,
Dave
DanDan
BX1860, L2600DT
Sep 21, 2012
125
SoCal
Thanks,
Dave
It's going to be pretty near then engine's rated speed; specs in the manual for my BX1860 are 3142 rpm to get the rated HP and 540 rpm at the PTO.
That's a big tiller for the little beast.
How's it working out?
2,849
Yup like dandan said wide open,,
Also do not try to sump that bad girl in dirt that has never been worked before,,, run it down about an inch or 2 at first do the whole area then drop it down another inch or 2 and keep doing that over and over until your down to the full depth of the tiller that way you will find roots rocks and all kinds of other stuff that can make for a bad day running your toys
1,006
OK there are three RPMS to discuss - the one selected for the PTO and the one for the tractor engine, and the rated RPM of the implement (this RPM is not changeable)
Assuming that your tractor has multiple PTO speeds - some do, some don't - select the gear that produces the correct RPM for the implement. Usually the implement is a 540 RPM implement and the correct gear is #1 on the PTO selector (for example my L185 has 3 PTO speed - #1=540RPM, #2 = 700 RPM and #3 = 1000RPM)
The engine RPM is the same for all three speeds and wide open is close enough. In reality there is a mark on the tachometer at 2430 RPM engine that gets the "exact" PTO output shaft RPM.
As you can see I could run a tiller/mower/post hole digger that is rated at 540 RPM at near twice the implements rated speed using the 1000 RPM selection for PTO speed. I am not that brave so I always run them at the implements rated speed - in my case all are 540 RPM - and I believe that is the common implement speed in the USA.
If you have only a PTO on/PTO off selector - then ignore all my blah, blah blah...and run it at near full engine speed like the others have stated.
davesl708
Feb 24, 2013
40
Shawnee, Kansas
Just an update on my post. The 5ft tiller had no problem breaking sod. The BX2200 did not complain a bit. Munched the clay and grass just fine. I ran it full throttle and went 4 inches at a time to full depth. Tilled 1/4 acre with it.
Great little machine.
retiredlawnboy
M6800, L245DT, L245H, Gravely 816T with Cab and Wing Mower, 5665, 1960s Li
Nov 24, 2014
Danville, OH 43014
I have been using one of my L245DTs with a 5' tiller to break 3 acres and cultivate for 5 or 6 years. The override clutch finally went out. At $2000 dealer repair price I have decided to use a mold board and middle buster first. I did aquire a used clutch, had to crack the tractor in half and replace. The beating the tiller and tractor go through to break ground is more than you realize, Just be aware of the possibility of beating up the inside of the tractor too.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
I'm with you. Breaking ground is harsh on a tiller unless its wet or loamy to start with, but it sounds like the OP got it done without a major malfunction.
I know I'll take the advice you're offering lawnboy and moldboard my acre of a garden I want to plant first, then run a tiller on it. It's what I planned to do anyway, but at least I should find all the big rocks with the plow first, but you're reinforcing my thoughts as well! LOL!
5,167
You guys are cracking me up with the tilling and mowing advice! :p
About the only thing I could till or mow would be snow and Ice! ;)
2,849
LOL,, your funny Wolfman,, not all of us live in the tundra,,,,lol
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
To re-invigorate this post - Russell King's advice sounds good. Not sure what full throttle is, no tach, but wind 'er up and go?
