4590 backhoe on L 3650 upgrade.
jgum
L 3650 kubota
Apr 17, 2022
60
West virginia
Would it self destruct if i plumbed a remote to the rear of my tractor that i could quick couple my backhoe hydraulics into and bypass using the pro mount hydraulic pump???? Any advice or ideas appreciated
10,776
You can do that but it's going to be much slower and have less power over a remote hydraulic pump.
If you do it flush all of the system out and use the same fluid as your tractor in it.
jgum
L 3650 kubota
Apr 17, 2022
60
West virginia
I thought since the pump had less gpm than the tractor it would make it more powerful to use the tractors hydraulic pump
Jchonline
600
Red Feather Lakes, CO
Your tractor pump has to run other things like power steering, hydrostatic transmission, etc. If the pump were strong enough Kubota probably would have matched a backhoe with no secondary pump in it. Look at the B26, L47, M62...they all have internal pumps for the backhoe. Could be wrong but I think the M62 had 2 pumps.
10,776
It might be, and if so you'll be fine.
7,005
If the tractor pump produces more flow and the same or greater pressure as the PTO pump it will work just as well if not better than the PTO pump. You need to know those numbers.
10,776
The BL4590 had a factory 5 GPM pump and the L3650 has a 7.8 GPM main pump.
So you'll have enough flow.
jgum
L 3650 kubota
Apr 17, 2022
60
West virginia
I believe I’ll leave it alone designed that way to begin with. I’ll plum it in if my secondary pump on my backhoe fails
5,184
The L48 TLB actually has 3 hyd. pumps
10,776
Wolf man my l3650 needs a wiring harness but I’m having trouble finding stuff for it do you have any suggestions?
I've been able to find plug end sets on eBay and amazon in the past.
I'll look and see if I can find the listings.
And you can get all the right size and color wiring on ebay too.
10,776
Give me a few more days, I haven't gotten a chance to look at all my notes on these.
10,776
