3pt attachment hydraulic relief
ichversuchte
Enola, PA USA
Hello,
I have a grapple for my b2650 which uses flat faced couplers. I only use it every few weeks and typically run into issues hooking it up every time. The grapple is in a cool place but the pressure still seems to be built up so that I can't hook it to the tractor.
What is the best way to relief pressure on a detached implement without threading off off one of the flat face couplers?
Thank you,
Brandon
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,043
Williamstown Ontario Canada
The time to bleed of the pressure in the implement is when you are removing it.
Once removed, the implement needs to be supported so that it is not leaning over and generating internal pressure.
My technique is to turn off the tractor and then move the control levers through their various positions to bleed off and high pressure oil.
Dave M7040
ichversuchte
Enola, PA USA
Dave M7040
Thanks Dave. When the tractor is off will moving the level relief the pressure though the third function valve? Not sure how the mechanics of the 3rd function works?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,043
If the valve for the grapple is activated with an electric switch on the joystick for the FEL, I would have the engine off but the key on.
Any valve should allow flow in and out so I think this will solve your problem.
Dave M7040
8,755
The other thing to do is attach the 2 hoses of the grapple together. ;)
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
That's a good idea Wolfman, it would keep the connections clean as well.
Woodstove
B2650-LA534-BH77- 60"MMM-72" scraper blade
Jul 4, 2017
9
Hagersville ontario Canada
Hi I've tried connecting the hydraulic lines together and had a hard time getting them apart. For me a put a rag down on a hard surface of the implement and give a hard tap of the male end of the hydraulic line and it will relieve the pressure and a bit of oil.
jajiu
Jun 5, 2016
456
I have been using the flat face connectors for a while and I find even when you take the implement off and go thru the steps to relieve pressure, it still builds up and is a problem connecting again. They are great for not dripping fluid when you disconnect, but sometimes I wonder if the problems out weigh the benefits. They are expensive and I have them on my front mount units, so I will live with the difficulties, but my rear mounts are the easy connectors that drip a little, but work very easily.
