Hi all,
Recently replaced my seat with an inexpensive "Kubota" compact tractor seat from Tractor supply. Not a bad for low buck. However does not fit without a bit of modification to mounting assembly.
Would very appreciate advice.
I was planning to lube all needed points of the seat mech. but could not see how best to lube the rotating mechanism which allows the seat to be rotated from using the rear backhoe position to the front position. I was reluctant to take it apart. Think maybe I should just "squirt" a bit of oil where I can and let it flow in the space?
JS
JS
