2010 BX 25 seat mech. lube
jbsealy
Kubota BX25 Backhoe and FEL
Mar 20, 2011
Stokesdale, NC
Hi all,
Recently replaced my seat with an inexpensive "Kubota" compact tractor seat from Tractor supply. Not a bad for low buck. However does not fit without a bit of modification to mounting assembly.
Would very appreciate advice.
I was planning to lube all needed points of the seat mech. but could not see how best to lube the rotating mechanism which allows the seat to be rotated from using the rear backhoe position to the front position. I was reluctant to take it apart. Think maybe I should just "squirt" a bit of oil where I can and let it flow in the space?
JS
jbsealy
Mar 20, 2011
Stokesdale, NC
ERROR!!!!!!!!!!! The seat replacment came from Northern Tool. Has nothing to do with the issue I ask about, but to those looking for an inexpensive seat.....
JS
BXHoosier
BX24
Jan 21, 2018
493
574
Indiana
I used garage door synthetic spray lube on my BX24 seat since I had a partial can laying around. It works great.
