After a recent purchase i have just replaced the cylinder head and got it running and noticed the oil light on at idle. Did a pressure test and basiclly non at idle and about 14psi at high revs. Did a bit of research and found out about the plug coming out of the end of the cam shaft. I stripped out the front and had to drop the front of the chassis down to get the timing gear cover off. Once off , No pug in the end of cam. Threaded and mad plug then welded as well. Will report on rebuild
