Hydraulic Problem
skratch
front and rear hydraulics
Sep 18, 2019
47
bernardo, nm
I have an L345DT Kubota, I have to bleed the hydraulic system every
time I use it. Lately it fails even when I'm using it. The oil is milky & looks
like very small bubbles. I bleed it at the line under the pump.
Thanks for any ideas,
john
4,391
Sounds like moisture and air in the system. Bubbles are air, milky is probably water. Does it set out and then does water get in around the shifting lever boot?
4,524
Check at your hydraulic pump where the lines tie into it. On most of those older models they use a rubber sleeve to tie the suction line into the pump. If you have a pin hole in it or a loose clamp, the pump can suck air.
Sent from my SM-G965U using Tapatalk
5,113
Like both before have said, water and air in the system.
Drain the fluid, clean the suction screen, check the suction line for any wet spots as those are suction leaks.
skratch
Sep 18, 2019
47
bernardo, nm
I've read that the early L345 tractors used 80w gear oil in the tranny &
hydraulic system. Mine was bought new around 1980. Would 80w be
less likely to foam ? I changed the fluid and cleaned the filter not many
hours ago, it's been a long time problem. Maybe the original owner changed
out the 80w to fluid.
D2Cat, the shifter has a metal spring loaded cap, no rubber boot. I'll try
to find one that will cover it all.
Daren, the small metal line connects directly to the pump, the larger line
has a flexable coupler from the filter, I'll check it.
Thanks to all,
5,113
Thanks to all,
The question I have is what fluid do you have in it now?
The use of 80w has long been dumped for modern hydraulic fluid, and no it shouldn't foam, like we said if it's foaming it's either sucking air or has water in the fluid, and one fluid change will not always get all the water out of the system, sometimes it takes several tries.
skratch
Sep 18, 2019
47
bernardo, nm
Another question, did the L345DT have a rubber shift lever boot ?
I ordered one but received the stamped sheet metal cap, called
supplier, they said no such part was shown. :confused:
Thanks,
John
5,113
In order to get better info it would help if you answered the questions put to you. ;)
They don't say what material they use, and there is an inner and outer shield on that model tractor.
motionclone
May 4, 2018
1,398
992
Maine
Thanks,
John
There is a rubber boot under the shift lever, have to remove the top of the shift box to get to it. Mine was leaking out the shifter on steep hills after fully warmed up and fluid expanded. My boot was torn and leaky. https://www.messicks.com/ku/85349?sectionId=219370&diagramId=361232
I have an L345DT.
Here is the part# I ordered and worked although
Kubota: SHIELD, PTO S-CH, Part # T0270-23870 https://www.messicks.com/part/t0270-23870/shield-pto-s-ch
skratch
Sep 18, 2019
47
bernardo, nm
I have an L345DT.
Thanks for the info, I finally found a schematic with your info, turns out
the problem on the shift lever water seal was simple, just an O ring under the metal cap.
It's on order, got the flex coupler for the suction line,
Obvious I'm not a tractor person,
Thanks to all for the help. :)
I don't have much to offer in return on tractors but I used to be a gunsmith,
my specialty was research, repair and restoration of antique and historical
firearms. If I could be of any assistance in that respect I would be glad to
help.
Thanks,
John
Fordtech86
L3200
Aug 7, 2018
4,792
5,628
Pineville,LA
help.
Thanks,
John
I may PM you some questions and pics when i can get them on an antique gun if you don’t mind.
skratch
Sep 18, 2019
47
bernardo, nm
I've drained the milky oil out of the gear case, filter and lines, if alcohol absorbs water could you
pour a gallon of denatured alcohol in the gear case to sort of flush it out ?
Seems the remaining alcohol would evaporate over a couple of days.
Just another crazy idea ,,,
4,061
re: Seems the remaining alcohol would evaporate over a couple of days.
then what's left would STILL be the water..........
simply fill with correct oil, get hot( run for say an hour), then drain it again, overnight or longer. Replace any filters as well.....
Jay
5,113
That crazy idea could cost you thousands in damage, DON'T DO IT!
Alcohol and hydraulic systems don't play well together.
