L4060 not getting fuel suddenly
Ridelght
2022 Kubota L4060 Polaris Rangerxp800 Ford 3400
Feb 16, 2022
444
301
Hi, My 2022 L4060 is giving me issues. It happened las Saturday, it was running like normal then started bogging like the fuel tanks empty. The gauge showed 1/4 so in my tractor that's 4-5 gallons. I pulled it back to the barn at first I thought the gauge was off so I filled it up. Did nothing, so bled the system, cleaned the water separator, replaced the inline lift pump and canister filter. It ran 45 minutes then died again. I even tried running direct from a diesel can to the pump to isolate where my issue may be. That did not work.
Any ideas on what could cause this suddenly other than a blockage? The inline pump sure seems small to pull fuel from under the tractor.
Thanks in advance
11,058
Pull the bleeder screw, turn on key.
Are you getting a steady flow of fuel?
Ridelght
Feb 16, 2022
444
301
I just bled it again with the screw all the way removed. Got no fuel at all that i saw. But it started for few minutes then quit.
Could the check valve that helps the inline pump cause this?
11,058
It's not a check valve issue.
Sounds to me like you either have a completely blocked fuel line or your electric fuel pump is not working.
Have you checked the fuse for the pump?
Ridelght
Feb 16, 2022
444
301
Yes, and replaced the pump with a oem Kubota. The pump has power and clicks.
I had the seperator apart and cleaned everything as my manual said to do. I then blew air through that inlet line in to the tank. Saw a mist out of the tank. I had transferred pumped all the fuel out.
I then blew air in reverese.
Then i replaced the inline pump and canister filter.
Put 4 gallons fresh fuel from brand new can.
Same results, bled saw no fuel at bleeder but the tractor started, acted normal for 5 minutes then died.
Ridelght
Feb 16, 2022
444
301
With saddle tanks under, how does fuel run up to the seperator unless the pump siphons it? The check valve i found on Messicks says it maintains pressure. If it sticks open fuel can run back to the tank.
Im going to try replacing it next. Then guess sending to the dealer.
3,092
Look at the inlet side of the filter/separator for a 90 degree elbow into the canister area. If there is one, they often get clogged with grass/bugs…so need to be cleaned.
It seems like a clog of some type that allows fluid through slowly so can build up at night but not enough to run continuously.
Maybe a vacuum in the tank so loosen the cap slightly to vent it and test.
Ridelght
Feb 16, 2022
444
301
Thanks. Mine has bolt on fittings at the seperator. I did not check that though.
11,058
I am not familiar with your tractor, but I do know that sometimes there is a filter built into the banjo fitting in other applications.
No inlet filter on that model, but the housing and fitting can get clogged with debris. ;)
Ridelght
Feb 16, 2022
444
301
Thanks, im in Ohio, tomorrow im starting square 1. Im sure its something simple. 95 hours on this tractor and ive done all the maint records. Very puzzling and my 1st diesel.
Thank you, ill look at the banjo bolts and just replace the seperator filter. I cleaned it before in kerosene. Thats what my manual says. When i thought it was fixed, it ran 40 minutes i put 4 gallons back in. I kinda got frustrated blew out lines again with the cap off and sprayed a gallon out on yo my driveway. So it sure flowed from there. The 1 thing ive not located is the vents on the tank. Also my bleeder screw has a tiny rubber hose that looks like it goes all the way back under the cab. I really do appreciate the help from you guys that have worked on these for years. Oh 1 last thing i took samples of the 4 cans of fuel i siphoned out, zero water after few days in clear containers.
Thanks again
3,178
1,295
Thanks again
Have you tried running it with the tank cap loosened to make sure the tank vent in cap is working?
Ridelght
Feb 16, 2022
444
301
No, i did with the cap off though. Not just loose.
Ridelght
Feb 16, 2022
444
301
Wanted to update, it was my inlet. I removed the seperator off the tractor tipped it to that side a tiny bit came out. Turned to outlet ran out fine. No screen or filter but partialy clogged. I used a weed eater string gently pulled out the gunk. Then ran a good stream of fuel out it to be sure open. Put it back on, it filled instantly from the inline pump, bled it. runs perfect.
Thank you all and hope this helps others!
