Loose push rod
Jeepyweepy
BX2370
Feb 5, 2024
9
NC
Hi all, a little background… mowing a field with my BX2370 and the tractor suddenly quit. I could hear the radiator bubble due to over heating. Let it cool and found a plugged screen. When it started, it had no power and pouring white smoke. Assuming head gasket, I began tearing it apart. Once I removed the valve cover , I could see one of the push rods was no longer under the rocker arm. I removed the rocker arm and put it back together in hopes of an easy fix. But.. still running rough and white smoke. Any idea what caused the push rod to pop out like that? Before I pull the head, I thought I would post here and see what you all think the problem may be.
thanks All!!
Bobby
4,393
So you have a 10 year old machine? How many hours on it, what maintenance and when, etc. Just need more clues.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,392
2,312
Collapsed lifter, wiped a cam lobe, bent pushrod, sticking valve........could be any of em. Or a combination.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
564
169
Herald Calif.
Due to overheating something in the head seized. Lifters on your machine are not hydraulic so no issues there. Most likely you will find the cylinder head cracked. Kubota's generally don't blow head gaskets. If it got that hot most likely it will need piston and rings as well. Good luck with your project.
Kubota Newbie
Dec 28, 2010
531
81
Mount Vernon, Ohio
Likely that either the valve in question is stuck or that you dropped a seat from overheating.
Make sure the valve is able to move up and down freely.
No? There's your problem. If you can manage to get it unstuck carefully and it's not bent, it might run ok. But it really ought to be replaced.
Yes moves freely? Check the height of that valve compared to others on same tract (intake or exhaust). Is it a little bit shorter? Dropped seat. Will have to be replaced. If you have a way to check compression on that cylinder it would show up as little or no compression in either of those cases.
5,132
Cracked head!
And it's cracked through whichever valve popped the push rod off.
Jeepyweepy
BX2370
Feb 5, 2024
9
NC
Hey, it has 380 hours. Just the routine oil changes etc..
thanks All!!
Bobby
thanks guys! Appreciate all the feedback. I’ll pull her apart and share findings…
Bobby
Jeepyweepy
BX2370
Feb 5, 2024
9
NC
Check out the bottom valve. When push rod came out of rocker arm, the tappet fell on top of the lifter. That cylinder was full of water. The metal gasket is pulling apart. Am I safe to assume that’s not normal and just get a new gasket? Push rods are all straight and all valves move freely.
Workerbee
Zd21
Mar 1, 2020
157
45
MN
Is the piston coming up to the same height as the other two? That water in there could easily bend a rod
5,132
Did you find the missing valve cap?
You need to check the head for cracks, take a picture of the bottom especially around the valves.
The head gasket delaminating could be an issue, but they do that sometimes when you pull them.
Coolant could have been trapped in the head when you pulled it and just dumped into that piston.
As others said, you need to check for height of that piston as coolant in a piston will bend the connecting rods and or damage the piston and or rings.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
832
975
Pittsburgh
Yeash! Pics of combustion chambers, plz. With detail of the area betwixt the valve hades.
Jeepyweepy
BX2370
Feb 5, 2024
9
NC
Thanks guys!! I did find the cap. No damage. Here is the bottom side..
5,132
None of the sealing surfaces look good. :(
This looks possible?
5,132
Ok that looks better.
You really need to resurface the head.
I use a huge piece of sandpaper glued to a piece of very flat hardwood plywood.
Or you could send it to a machine shop to have it done.
