BX 25 Tire Ballast
motherjones
BX 25
Oct 12, 2012
9
carneys point nj
Just got the back tires tubed and loaded with something called Bio Ballast. Can't believe the difference! This Bio Ballast is supposed to be non corrosive. Each tire took about 10 gal. and added about 85 #s per tire.
2,825
good stuff, have it in mine also - never NOT had it, so i cannot tell what is was like not having it! :D
make sure if you add air or want to check the air pressure, do it at 12 o'clock!
3,088
But I usually eat lunch at 12 o'clock….
Sorry, when I read that, it struck me as hysterical & I couldn't resist.:D
3,088
Saw an odd factoid on the MSDS for this stuff:
Material can be corrosive to some metals; care should be taken when stored for long periods in metal containers.
Hmmmm….
8,704
That MSDS warning would be for Calcium Chloride ballast! The Bio Ballast is Beet Pulp Juice or brand name of "Rim Guard". Safe for the ground if it leaks and safer for the rims. Beet Pulp (sugar) No where near as corrosive as Calcium Chloride (salt) in your rims.
3,088
2,825
Like the MSD sheet said "It does not contain any hazardous components"
hell , if at 12:00, and you are hunnngry ,take a sip, I imagine that beet juice will put a little getty up in your step!!!
