Rusty Metal Pre-Treatment Products ???
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Has anyone used a rusty metal pre-treatment called Rass-O-Nil on their tractor engines?
I don't have the time or energy to do a complete strip down and paint of my B7100 right now. Yes, I am envious of those that have made their B6000 & B7100 look like new again. The block is starting to look very rusted and shabby. Was hoping to do some type of quick rust conversion and rattle can coverup to keep further rust at bay.
What products have you used that worked out well for you?
hodge
Nov 19, 2010
2,950
514
Love, VA
I've never heard of Rass-O-Nil, but I have used POR-15 with great results. But, I haven't used it in a high heat situation, so I don't know how well it will perform.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Sorry.......there will be no splash-n-dash solution.
None of the rust conversions will work on greasy/oily surfaces. Degreasing will be the bigger part of the job and you'll need to strip it down anyway.
I bead blasted mine.
Frank46
L3800 La524 loader
Nov 4, 2013
87
new Iberia,LA
I've used one or two rust paint over solutions but had to wire brush 1st and then clean before painting. It does not leave a smooth brush less mark surface. The more prep you do the better the finished product will look. Frank
183King
Bx1500 w/ FEL, MMM and PTO Bagger
Jan 5, 2016
MA, USA
We use PO-15 on our truck fleet and we have not found anything on the market that is better. I believe if you check their site they make 2 solutions for stripping. It is pricey but you will never have to do it again. It's all in the prep.
aeronutt
Z725 Mower, MX5200 w/FEL, Stihl 660, assorted others...
Jan 7, 2016
120
Omaha NE
...None of the rust conversions will work on greasy/oily surfaces. ...
If it's rusty, it's probably not oily. POR-15 is expensive, but works wonders.
BTW, there's no such thing as "just a little now until I get around to doing it right" around my shop. If I do a halfway job, that's the way it will stay forever. Might as well go ahead and do a good job the first time.
JFK52
L345DT
Mar 3, 2016
15
Rio, WI USA
I have used a solution called OSPHO. I am currently redoing an older one row tree planter that sat out in the pines for 20 years. I plan on selling the planter.Sprucing it up by taking off the rust and matching the original paint color will make the sale easier and bring a few more bucks for the unit.
