Early yesterday I took my piston assemblies to the machine shop that was touted 'to heat pistons' to insert pins.
They seemed to not have heard about heating pistons. Also said their good machinist was retired & came in only when needed.
So I then went to the machine shop used by the other Kubota dealer. This dealer & the machine shop said the pistons were 'press fit' & did not need heating.
My assessment yesterday morning,
- long time in business
- build & ship engines all over the U.S.
- have many, many, repeat customers
- have always done 'good' work for me in the past
- used by local Kubota dealer
- really, really, a nice owner to talk with
Because of this I asked him to:
- pull the pins, check for anything that should be replaced with new,
& put in new bushings (properly fit)
A couple of hours later I picked up the assemblies & didn't think about looking at the work at that time. Later that evening I was looking at one assembly & noticed that the rod bushing was exposed on one side but not the other. Looked at the other two & they were the same way. Edges of new bushings show edge damage.
My concern is the bushings are not centered & would not center the load properly & 'might' have reduced the oil hole opening by the offset amount (can't tell because it is at the top of the rod).
The new piston appears to have two cracks in the bosses, one on each side. They catch my fingernail if I scratch them. Might not be cracked but visually appear so. If they are cracks then this is probably because it wasn't heated. The picture does show the cracks but not at first glance.
Also looked at the old bushings. Looks like one was removed with the aid of a chisel. That's ok as long as the rod wasn't damaged.
Talked this morning with Country Sales & Service - Ohio". They are a Kubota dealer & also rebuild engines. The service manager told me they would look at the three assemblies, check for damage, round the rods, replace anything that 'needed' it, center the bushings, & they routinely heat the pistons if it is called for.
Will be packing them later today.
Pictures are included.
