MX4800 HST oil change…go synthetic or stay with Kubota brand?
trackman23
MX4800
Nov 22, 2023
124
25
NC
It is time to change the engine oil in my mx4800. The machine has 1200 hours and poor historical records on types of fluids used when serving the machine but there are no known issues, no leaks, no fuel consumption etc. I do not know what type or viscosity oil the previous owner used, I just know it is time to change it.
is there any real point in using one oil over another assuming that the correct viscosity is chosen? I live in NC so we see hot and cold but the tractor stays in an enclosed barn so it probably won’t see “cold start” temps much below 50 unless it is left outside in winter for some reason so I plan to use 15w40 as per the manual...only question is which one?
thx!
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
73
29
Va
I just switched to T6 Rotella. 15w40. In my B2650 with 304 hours on it. I was using reg 15w40 I asked my mechanic about it before I switched and he said as long as it’s a high quality oil. Your fine. And Rotella is a good oil
3,092
There is STILL bad rep on synthetic oils - from break ins, to switching etc.
I use synthetics in everything - Mobil 1, T6 and Amsoil.
There really is NO reason NOT to use synthetic oil.
This guy has forgot more about oil than most know - he does it the old fashion way - via science!!!
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,230
1,850
Pittsburgh
Where it concerns lubricants there is only one correct choice.
trackman23
MX4800
Nov 22, 2023
124
25
NC
I don't believe I have ever had one of those!! ;)
I know! There’s a chance even by just putting in the 15 W 40 Kabota stuff from the dealership that something goes sideways! Nobody knows what magic juice is in this engine and I did just notice that one of the copper gaskets is missing from the oil drain plug and it’s not even leaking there lol.
3,796
2,198
Did you read carefully what you typed and I highlighted in red?
5,581
I use Rotella in all my diesels, but if it makes you feel better, the Kubota oil should be just fine.
I have switched from T3 to T4 to T6 depending on what deals I find. I have never had an oil related failure of any sort.
IMHO most/all "diesel rated" oils will be just fine.
YMMV.
Good luck (y) (y) (y)
7,379
Synthetic engine oils outperform conventional oils. Thats a simple fact.
Whether the gain is worth the added expense is a personal decision only you can make.
trackman23
MX4800
Nov 22, 2023
124
25
NC
I went for it. I picked up Shell Rotella T6 15W40 for $1 less per gallon than the Kubota conventional oil!
plumber mechanic
Kubota L2550D
Sep 18, 2023
58
I've been considering switching from conventional oil to synthetic in my Kubota L2550 (758 hours). After looking at the lab video posted in this thread, it sounds like synthetic is the best way to go. Can you get a good synthetic oil in 10w 30w as recommended in the owners manual (I'm located in southern Pennsylvania)?
Thanks for any of your help and input om this subject.
7,379
Multiple chouces - here is one
