Loss of multi function
Parannor
BX23S
Oct 10, 2026
Wa
Hello I have a BX23S recently I seem to have lost the ability close my grapple and roll back at the same time. I know I had this ability before. I was behind on maintenance due to a layoff but today did hydro filter and fluid replacement. It did not fix the problem. Am I looking at bypass valve leak by?
*** I realized with that first reply TY btw that I need to add another detail. I haven't totally lost this ability it stops once the grapple is closed. So with nothing in the grapple I can grapple close and role back at the same time until the grapple fully closes then I lose the ability so I can't hold pressure with the grapple while rolling back to keep pressure on stuff I am picking up any more. ***
11,301
I have the factory 3rd function it is a bypass but it bypasses loader up.
What your explaining is a diverter not a true third function???
How many hydraulic lines go in or out of the 3rd function valve?
7,377
I think we need more info on exactly what you are doing.
Sounds like you have the typical third function valve. While the grapple is closing it is passing pump flow down stream to rhe next function. When its fully closed and you hold the button down it.blocks flow from both downstream and upstream functions. When you release rhe button flow to and from those functions is restored.
How that effects simultaneous operatuon of bucket and boom depends on whether the third function was instslled upstream or downstream of the loader valve.
If installed upstream holdung button with grapple closed blocks all loader functions.
If instslled downstream and you are holding grapple shut:
You can dump and curl bucket all you want.
You can only raise and lower boom while bucket is moving.
Do tell us more about what combination isnt working
Parannor
BX23S
Oct 10, 2026
Wa
Yes it is a diverter style (I said bypass) but the loop it is diverting in loader up and loader down not the curl function. I should add it is the Land Pride 2 button one.
So right now I can hit my close grapple button and move my joystick left and the grapple closes and the curl back works once the grapple fully closes the curl stops. This is standard function and is intended so you can maintain closing pressure while lifting or curling. I have a 0-3000 PSI GF Gauge coming and a FF 1/4"NPT.
I is somewhat hard to tell but it does seem a touch weak in a lot of the pressure functions lifting with the pallet forks seems to work harder and the hoe I think was stalling sooner then it used to, but that is just feeling not actual factual measurements that I can give.
7,377
Thats a whoe different hydraulic circuit - one I never considered befire and shall we say "interesting.".
With that arrangement the flow is in to boom section, out to the grapple diverter. Then to cylinders, back again to the diverter and back to neutral out on boom section. From there it goes to neutral inlet on the bucket section. . With that setup as soon as the grapple cylinders stsll there is no return flow from the grapple and no way to operate the dump/curl function. Never ever..
Parannor
BX23S
Oct 10, 2026
Wa
Here is the manual for the LP3rdF. I apologize if I seem to be coming across snippy it is not my intent. I am frustrated with myself I have 200hrs on the machine and probably half of that is performing the action I am failing to describe, it is just one of this things you know has changed but can't describe it well enough you just know.
7,377
That is not a diverter. It is a full function directional control valve that is installed in the power beyond circuit of the loader valve.
You can use boom and grapple at the same time but using bucket will block grapple If grapple is stalled (held closed) bucket will work fine but boom will only work in combination with bucket.
Now tell us exactly whst combination used to work and now does not.
Parannor
BX23S
Oct 10, 2026
Wa
Ok lets see if I can do this Youtube thing. lol. I took a short video you can see I am curling back and closing the grapple at the same time as soon as the grapple piston maxes the curl stops if I release the button for the grapple the curl comes back. I think I might be hearing the overpressure when this happens but I am a 50yo Veteran with less then 100% hearing.
I did look at the cap on the relief valve spring. Is that supposed to have a gap to the between the Hex and the body of the valve. It felt tight. I did blow the wrap around like once because I got it pinched putting the hoe back on. The local tractor shop made me a new one and I put it on but I think it was working correctly after that this feels like recent change.
7,377
Looks like the closed grapple is blocking the return to tank circuit on the bucket. Thats why you hear the relief unloading the pump
That should not be possible. In fact just opposite '- bucket blocks grapple. Repeat that but use dump instead of curl.
Meanwhile let me ruminate on how this could manifest out of nowhere. Whats the loader model number?
Parannor
BX23S
Oct 10, 2026
Wa
LA
LA340
7,377
Has anyone changed anything in the hydrauluc system? If the 3rd function was installed as described in the manual its after the loader valve and there is no way for the grapple to stall the bucket. Yes, I saw the behavior and thats why I am questioning the plumbing.
Parannor
BX23S
Oct 10, 2026
Wa
Just two hoses strait across not a change. Blew hose had new hose made replaced hose. One on the grapple and the return house on the back.
3,165
Maybe the hoses got one end swapped so they are now crossed from previous situation. If you replaced one hose completely and then moved to the second hose then this is not a possibility. If you attached both hoses at one end then moved to second end and replaced those ends then this is a possibility.
Just a possible issue to resolve.
