BX22D priority valve
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
Denver North Carolina
Where I circled is that the priority valve spool my steering is hard to turn. I replaced seals in turn cylinder and that didnt help so Im hoping the valve has some trash in it that has the valve stuck open/closed. The orbitle valve is working as it should. Screen in suction line is clean and filter has been changed as well as fluid Kubota udt2. Been rebuiling tractor.
7,310
Why not check for flow at the steering valve?
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
dont have the right fitting for guage. I got this unit on the cheap and restored it trans/hydraulic tank was really dirty screen was packed full of debris cleaned screen changed filter and fluid repeated the process. Steering did not work when I finally got the tractor started so I removed cylinder and repacked it bled air and still no power steering at fel line I put my guage on and got about 1100 psi so Im low on presure so I put a .1 , .2 and a .4 shim in releif valve that got me about 1300 still way low presure. FEL works fine and runs great forward and reverse. So I thought the priority valve spool may have trash in it. I think the pump is good but it may be wore out not sure. So I thought maybee someone could tell me where the priority spool was so I could pull it and check for trash. Or maybee I need to pull that whole valve assembly. I have totaly restored and painted. Working on backhoe next.
7,310
A good pump makes 1800 PSI. If you are measurung 1300 PSI either the pump is bad or your not hooked up correctly.
Forget the gauge, are you getting oil flow at the IN port on the PS controller?
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
im hooked up correctly pump may be bad. I got one coming. Still maybee the prioity valve. and yes fluid is at controller. All rubber hyd. lines have been replaced.
11,141
If it's that low on pressure and flow the priority valve will stay closed.
7,310
The priority valve is pressure compensated and will stay open at any pressure and fkow under 2 GPM. PS always has priority and will always get punp flow up to 2 GPM.
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
flow rate is that what you are saying. The priority spool if it is stuck one way the fluit may not be getting to steering side. I bought the jailbreak system and had not known the pump presure before I got the kit because I did not have a guage but now that I do the presure is reading low so your saying even at 1100 psi I should still have steering because it has priority first but if the spool is stuck in the wrong direction in theroy steering would not work. I say that bcause all the trash that was in the system could have gotten by the screen and filter. But it is proabibly safe to say the pump is bad if im getting 1100 psi at full throtle and 1300 psi with all three shims installed. so maybee 2 issues
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
Yoy can easilt neasure fkow rate
Disconnect the pipe, put a clean bucket under the end, start tractor and time how long it takes to fill it to the 2 gallon mark. Pour oil back in tractor.
so when you told me to see if I had fluid on the presure side of the steering valve I just cracked the line and bumped key and I saw fluid so I thought it was getting fluid after pulling tractor back apart to check everything and I pulled the priority valve it was good by the way the guy that I bought it from must have been messing with the steering because the presure and tank line where reversed. When I changed all the lines on the tractor I just marked them and put back where I found them. Well never trust another mans work lol. Thanks for the help. The pump presure problem I checked pressue at the bucket tilt side and was getting the 1300 psi put guage on the up down side and had 2000 psi the bucket side spool must be bypassing will have to pull spool and inspect. Good news pump is good and steering works
7,310
How does a spool bypass in that fashion and how would you find and fix it?
Lumberjack1012
Kubota BX22D LA210
Jan 17, 2026
39
14
bad nylon or rubber orings inside spool replace them I dont know if they are in these but I have pulled many a spool in my time and found bad nylon ring in alot of them . Now that was in heavy equipment never in a tractor.
7,310
There are no orings. The pressure seal is metal to metsl.
7,310
Pl
with all do respect why didnt you just say so if you knew the answer.
I assumed you knew. Metal to metal is standard design in spool type directional control valves and has been since the 30's if not earlier. Thats why they all leak in neutral.
With that in mind how do you explain the low pressure reading you got?
