L245DT help
Eaglenest
L245DT
Aug 18, 2025
27
PA
Anyone know why when I lift FEL left side goes up faster than the right side and binds any help would be very appreciated
2,327
Possibly the cylinder seal has failed on the slow side so oil just moves from one side to the other instead of moving the ram?
Possibly there is some obstruction in the hose going to the slow cylinder?
3,426
2,009
Maybe a bent rod? Pictures or videos would help. You can post picture files directly, there may be a 5? post minimum before pictures are allowed. For videos, post on Youtube or other host site and post a link here.
Eaglenest
L245DT
Aug 18, 2025
27
PA
Thanks I’ll try
Eaglenest
L245DT
Aug 18, 2025
27
PA
Could it be the control valve?
Eaglenest
L245DT
Aug 18, 2025
27
PA
I don't see any way the valve could be causing your issue. BTW, is this something that started suddenly, developed slowly, has happened as long as you've owned it, etc.?
Recently purchased the tractor and started to fix it up and noticed this problem
Eaglenest
L245DT
Aug 18, 2025
27
PA
Even though there is no hydraulic oil leaking from the cylinder do you think it could be a seal thanks
5,652
Yes. Test the cylinders as follows:
  1. Lower loader and remove pins from both rod ends.
  2. Disconnect base end hose at loader valve and cap it if there is no quick coupler.
  3. Start tractor, set engine RPM to ~2000, move loader control lever to the "lower" position and hold it there.
  4. If the rod on either lift cylinder extends it's leaking internally
Eaglenest
L245DT
Aug 18, 2025
27
PA
Thank you I will try that. I’ll give results.
Eaglenest
L245DT
Aug 18, 2025
27
PA
Found the problem , a piece in the control valve was blocking the flow all good now
