Best attachment for removing pine needles?
Mustard Tiger
BX23S
Jun 26, 2025
45
76
Pacific Northwest
Last two years at the new place I've raked all the pine needles by hand. It takes forever. I had several burn piles of needles along with filling a 30 yard dumpster each year., with each dumpster holding 3+ tons of pine needles! It gets old real quick, let me tell you.
Wondering what the best attachment would be for cleaning up pine needles from the yard and gravel driveway? I've seen pine straw rakes from both Titan and Everything Attachments. The Everything Attachments version is twice the price of the Titan, and for such a simple implement, not sure it's worth the premium price.
Wondering if anyone has used either of these for my intended purpose and what your experience has been. Also open for other suggestions if you know of something differnt that is great for gathering pine needles. I really don't want to do this by hand anymore!
Thanks!
EA and Titan versions below:
8,695
Bearcatrp
Mar 28, 2023
855
491
Minnesota
Those tines are too wide for pine needles. I have the top one. I added the wheels and mesh. Check this link for pictures of mine. Haven’t used it yet.
biketopia
Feb 15, 2024
318
300
Warrenton VA
I have the Amazon version and it works great, just as intended and was under $200.
Mustard Tiger
BX23S
Jun 26, 2025
45
76
Pacific Northwest
I dont think the tines are too far apart. Pine needles are kind of like velcro. The nice thing about raking them is they kind of cling to each other and ball up and the more of them that are on the ground, the more they adhere to each other. And I'm not talking about a few pine needles. I raked up 3 tons of them into a 30-yard dumpster and burned I dont know how much just this spring, and that was after doing the same thing last spring.
torch
Jun 10, 2016
2,707
937
Muskoka, Ont.
I bought the Titan a few years ago for the same intended purpose. Works OK on leaves*, so-so on pine needles. Yes, if the mat of needles is thick enough they will jam together and the rake will drag most of the mat into a pile. But the rake mostly just combs a thin layer into straight rows.
*up to a point. Once the leaf pile gets up to a certain weight/density the tines fold back too much and start losing leaves off the bottom. At that point it's time to turn the tractor around and load the pile into the bucket for disposal. Backpack leaf blower (Stihl BR600) works as well or better on dry leaves, although the rake may have the advantage on wet leaves.
Also, care must be taken with getting the angle just right on lawns or it can tear up clumps of grass. Less of an issue on the gravel drive.
Old Machinist
May 27, 2024
365
384
NE FL
Around here they bale and sell them for mulch. If you have that many you might try contacting someone in that business to see if they would take them off your hands for free.
As far as picking stuff up without damaging the lawn a sweeper is hard to beat. A large area would be best done with the vac wagon type.
Mustard Tiger
BX23S
Jun 26, 2025
45
76
Pacific Northwest
All great points, and thank you.
Good think for me is I don't have a lawn, so no fear of tines tearing it up!
On one side of the property I started raking the needles into piles and just burning them there, and would have multiple smaller piles burning, so dragging them with the tractor and attachment until they start bending the tines seems like it would work and I wouldn't have do do so much of it by hand.
I also have a Stihl Kombi Tool with the blower attachment and that did surprisingly well with the needles on the gravel driveway.
Sidekick
Jul 29, 2023
979
1,284
N.Y,
I bought one of those needle rakes and sold it after the first use. My Cyclone rake will pick stuff like that with lift blades on my BX.
Bugzilla46310
2022 BX2680 198? AC 916H
May 22, 2022
184
185
Demotte, IN
I have burned in place. The few pines we have the lower branches have been removed so you can walk under them and they are not located in our “manicured “ lawn area. I do this with the oak leaves occasionally also. Of course we live out in the country.
Tim Horton
278
56
Lake Superior
Trivia.... Years ago I built a ...homemade... 3pt rake, 3 rows of JD bailer pickup teeth, 5' wide, that worked well.. At the time it was a less expensive option then the pine needle and other rakes availible..
