BX2350 gas pedal sticks occasionally or hydro bad
DKIRCH
BX2350
Apr 30, 2025
My
New to the forum thanks.
I have a 2007 Kubota bx2350 that I’ve owned since new. Recently the gas pedal seems to slick occasionally and goes really slow. Some times if I go forward to reverse it gets better. I’ve looked for obstructions and can’t find anything. Could it be an issue internally or hydros failing? I’ve recently drained the fluid, changed the filter and cleaned the screen. Everything looked perfect.
Any thoughts?
Sawdust&Shavings
Apr 25, 2023
88
77
Stafford, VA
Any thoughts?
Have you been greasing the “speed control pedal“ every 50 hours per the owners manual?
2,783
Not a "gas" pedal ....it is a hydraulic fluid pedal - changing the flow of fluid flow.
As sawdust mentioned - there is grease zerk to be greased.
What type of fluid did you replace with?
DKIRCH
BX2350
Apr 30, 2025
My
Yes I’ve greased it. Not sure if every 50 hours. But didn’t neglect it. Replaced the fluid with Kubota super UDT. I realize it isn’t a gas pedal lol
8,587
Sounds like you have an issue with the dampener, remove it and see if your problem goes away.
Also check the red circle that is known to come loose.
2,783
In NIW post the "nut" marked 140 is the problem - It backs off and causes slop in the movement.
Hard to get to - remove right rear tire to get a better look at it.
