Pinhole leak in metal hydraulic line
3,183
1,795
Another option is to use a compression to JIC adapter, then have a new hose made with a long 90° JIC fitting on the end.
5,099
I like that idea a lot 😍
Just cut the end off the existing hose and crimp on the new one. Any hydraulic shop can do that.
These convert-a-flare tube nuts, sleeves, and a plain JIC tube union are much less expensive than the male JIC compression fitting. I use all of those bits a lot and have them on hand. In addition to being a lot less expensive they allow you to skip dash sizes - e.g put a -08 end on a -06 tube.
3,183
1,795
I'd just caution OP to measure that hard line before ordering parts.
6,480
If/when you find a good hyd shop you will be able to come up with an alternative of some kind. I had a hyd hose blow on a '66 730 Case tractor two winters ago. I was using it to feed hay and needed it. The dealer could order the hose (It was about 35" long with a peculiar long 90 on one end), take a week to get it and cost $270. Asked him about about hose replacement since they makeup hoses. Said sure. A thirty minute wait and $77 I walked out with what I needed. Good luck with the project.
5,099
Exactly!!
3,132
1,555
Thanks all for your input! I went to a hydraulic hose shop as recommended. They did not think a compression or flare fitting would be a viable option.
The compression fitting is a good solution; I have used it and have seen it used many times. Just cut the tube back a little to get to a good section of the tube, and emery cloth it clean and smooth.
Their first recommendation was to tack weld it ALA Smokeydog.
Do not try welding it. The tube is worn thin and rusted—pitted. If you weld it, you will very likely get debris from the weld in your control valve.
Their second recommendation was to replace the whole metal section with rubber hose (I tried sourcing the OEM part [70050-00709] but it's discontinued and impossible to find.) They were thinking this is would cost about $150 to $300, which is actually less than I thought but still steep for a poor tightwad like me.
I have a friend that can MIG weld it for free, but not until next Sunday and I really need it ASAP.
A couple people have recommended JB Weld. I have some which is rated to 5000#.
Only in your wildest dreams would JB Weld repair a high-pressure leak in a hydraulic tube.
Do I have anything to lose by cleaning it up really good and trying that first?
Use a compression fitting and add a short section of hose to repair it. Just use two P clamps around the tubes rather than the c-clamp to hold the hose and tube in place.
forrest carver
L275
Sep 3, 2022
77
10
edgecomb, me
Hi all, thanks for the further replies and sorry for the delay. A little update:
Unable to avoid mistakes without without making them myself, I went the JB weld route. I gobbed it on liberally in two separate coats over the past several days. This morning after curing, I fired it up. As most of you predicted, it did not work at all. In fact, I'm not sure how but the leak is significantly worse now!
I have removed the whole section of metal hose and all the accompanying rubber hoses and will be bringing it to the hydraulic shop today. I will most likely replace the whole metal section with rubber hose, although I suspect the rest of the metal hose is fine (the section that rusted through was in a little crevice full of moist debris, and the rest is clear).
I had another question hidden away on the first page: being that I don't know how much fluid has leaked out, and I don't think the hydraulic fluid has been changed in 20+ years, I suppose the smart move is to drain out the rest of the fluid and add fresh. I found some conflicting information online about the capacity, where should I find that info?
forrest carver
L275
Sep 3, 2022
77
10
edgecomb, me
I was able to find a compression fitting and an elbow at Napa, total $30.
As you can see from the picture below, turns out the pinhole was just one of many issues with that joint on the original hose. I have no idea what happened to it but it looks like hell.
Thank you all for the advice and counsel as usual!
8,623
That compression fitting looks to be the 100% wrong type.
The brass is the giveaway.
Hydraulic fittings are always steel, as Brass can not hold up to the pressures.
If the loader runs off of a pump on the front of the tractor then it will have it's own fluid reservoir in the right tower of the loader frame.
If the loader runs off of the pump behind the Injection pump then the Sump or main hydraulic reservoir supplies the fluid.
forrest carver
L275
Sep 3, 2022
77
10
edgecomb, me
Well, shit! What will happen if I try to run this setup as is?
Dustball
2016 B2650HSDC
Sep 15, 2023
407
256
Hudson, WI
In addition to what others have said about not using brass fittings for hydraulic, do not use thread tape on compression fittings.
forrest carver
L275
Sep 3, 2022
77
10
edgecomb, me
Got it. I actually asked the desk person if I should use thread tape and he said yes (also, there is evidence of thread tape on all the other hoses on the tractor.) I guess it makes sense he also I will remove it, thanks for the advice.
Purely out of curiosity, why not? Bits of tape in the system?
5,099
Purely out of curiosity, why not? Bits of tape in à system?
The desk guy ia clueless.
You only use thread sealant on joints that seal on the threads. Thats pretty much limited to rigid male pipe connections.
SPECIFICALLY
You do not use thread sealant on fittings that do not seal on the threads:
  1. JIC
  2. ORB
  3. BSPP
  4. Compression fitting nuts
  5. Female pipe swivels.
forrest carver
L275
Sep 3, 2022
77
10
edgecomb, me
After snatching defeat from the jaws of victory a few times, I've finally gotten it fixed and working (with the right material fittings).
I have not replaced the lost hydraulic fluid yet, though, and I suspect this is an issue because after turning off the tractor and dropping the bucket, it lowers very, very slowly now (new development.) Could there be another, more insidious cause for this?
5,099
Your problem isnt caused by fluid level. Something in the return circuit is probably blocked. If you move the lever to float does it drop faster?
forrest carver
L275
Sep 3, 2022
77
10
edgecomb, me
Sorry, I don't know what "move the lever to float" means. When the tractor was running, it would lift and lower as normal.
Although I should note that even when none of the hydraulic levers were activated, the bucket was kind of "jerking" a bit, at the rate of once a second maybe. Come to think of it, this was actually just happening before the original leak.
5,099
Move the lever to the full down position then push hard. The lever will move past a mechanical stop and into the "float" position where the boom will drop freely. Read your operators manusl for details.
