Kubota Steering Stops
8,764
What do you mean steering stops?
Do you mean the old style bolt stops on the front axle bevel case?
No, you do not have those.
Do you mean the steering wheel doesn't stop at the end of the rotation?
That's normal for a Hydrostatic (hydraulic) steering system, you will also notice that the steering wheel zero location will always change , that too is normal.
rancher1524
Tractor LX4020 B3350SU
May 11, 2016
121
29
Evans, Washington
Sorry, I am talking about the steering stops that attach to the front axle and limit how far the front wheels can turn. They came installed on my Kubota B3350SU. The steering stops are listed as an option on the Kubota LX4020.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
169
Hardisty, Alberta
You can install them if your front wheels are contacting the loader frame. Otherwise no need.
Nomore67
Currently own- LX4020, B2601, IRE20 (mini-ex). Previously owned- BX1870, B2601
Apr 28, 2019
29
38
Minnesota
My understanding is that these (steering stops) are only needed 'IF' the tractor is optioned with the larger sized tires AND if equipped with the mid mount mower deck option.
I questioned this in detail when buying my LX4020. I do have the large size R4's (no mid mount mower), my tires haven't rubbed anything.
Sidekick
Jul 29, 2023
1,005
1,344
N.Y,
When I got pricing on the lx2620 cab stops were automatically added to the price with the larger tire option. Standard size tires didn't require them.
MOOTS
MX6000
Jun 27, 2019
2,166
2,690
Canton, Georgia
My LX2610 had them, I had the larger R14’s. There’s a picture here somewhere showing how minuscule they are.
MOOTS
MX6000
Jun 27, 2019
2,166
2,690
Canton, Georgia
Found the pictures. This was on my 2610, not sure if the axle is the same in the 4020.
Nomore67
Apr 28, 2019
29
38
Minnesota
I don't know all of the design / shape diffences, but the 3520 & 4020 model's front axle is 4" wider than the '10' series were. *the new 2620 may have the previous front axle, I'm not positive though.
I think the wider axle helps with clearance, getting the tires out little further from the tractor.
