engine dies when PTO is engaged
cyclehd
tg1860g
May 3, 2013
21
edwardsville il.
kubota tg1860g, engine dies when pto is engaged,PTO works when deck is removed. pulleys all good, belts good, mower has 41 hrs on it, sat for a few year, cleaned fuel system twice.
freewheel3
Mar 9, 2013
333
34
Alberta
What all did you do when you "cleaned the fuel system"? Was there much foreign material in the fuel system? Maybe its still plugging up? Can the mower assy be rotated by hand without excessive drag? Also check the ujoints on the pto shaft for binding / siezing (unless its belt driven)
Does it bog down and die from heavy load or does it just quit instantly as if a safety switch is shutting the unit down?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
80
Rocky Face, Georgia
Do you mean when you engage the pto it loads the engine up so bad that it dies or is it a electrical issue such as a safety switch?
freewheel3
Mar 9, 2013
333
34
Alberta
Great minds think alike.
uglyboy
TG1860G
Mar 8, 2013
87
St. George, Ontario
original post suggests no problem when engaging pto when deck is off.
I'd suggest you have a fuel problem (starving).
There is a fuel filter in the fuel line at the left side of the engine just before the fuel pump. Maybe it is restricting fuel flow.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
Sometimes and electric pto can appear to be good without a load on it, meaning it will spin free without a deck belt around it. Then when you put it under load it wont work at all and can kill the engine.
cyclehd
tg1860g
May 3, 2013
21
edwardsville il.
some times if I keep pulling and pushing the PTO on and off it will eventually turn the blades and cut grass, whats the fix
cyclehd
tg1860g
May 3, 2013
21
edwardsville il.
can the mechanical part of the PTO be fixed? the electrical part is working
cyclehd
tg1860g
May 3, 2013
21
edwardsville il.
no the PTO engages when the deck is off, when deck is onand PTO is engaged it kills the the engine, solenoid is engaging
Bulldog
Mar 30, 2010
5,434
80
Rocky Face, Georgia
Have you made sure that the deck is turning free when the engine is off. The electric pto is nothing but a clutch and normally either work or they don't. I don't see how the pto clutch is what's locking the engine down.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
Start simple and start cheap and replace the electric switch that controls the pto. Its starting to sound like a faulty switch thats going bad.
OkieDavid
L 3010
Aug 29, 2012
46
Valliant, OK
I would start with the engine RPM running a little faster than idle. Sounds to me like it just can't maintain the RPM with the sudden load (fuel issue). Could be an issue with the governor not throttling up under load as it should.
The key diagnostic to me was where the OP stated they could rapidly engage/disengage the PTO and get it to operate. Sounds to me like it just needs to "spool up" gradually thus decreasing the load on the engine. Higher RPM at start up may solve the issue.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
Its going to be a simple fix of replacing the pto switch. If he's having to turn it off and on by more or less wiggeling the switch then its safe to say that it's a fulty electric switch going bad. Its a cheap 10-15 dollar fix.
cyclehd
tg1860g
May 3, 2013
21
edwardsville il.
yes i think your on to something, but the throttle is at its max its not throttling up when i put the PTO in, the govener is not working right , whats keeping that from working
cyclehd
tg1860g
May 3, 2013
21
edwardsville il.
by turning it on then off quickly thats just to keep the engine from dying, its really not reving up when i engage PTO, why isnt the engine reving up when i engage PTO? how does the govener work on this model?
