Snowblower?
Mowbizz
Bx25d
Aug 19, 2021
553
314
For those of you in the northern climates, when do you put your tractor snowblower on? I’m wrestling with this now…Central NH is a pretty good snow belt. My FEL has helped me immensely this summer and I think I can do without it now.
I think the next sunny day, I will do the change-over to the winter mode. This year I also have a new side by side (Kawasaki Mule) with a power angle plow to add to my armory…I dug into that yesterday and flipped the plow edge. Previous owner had plowed the edge down to the bolts but I still had “meat” to flip it. Had to drill new holes to get it on but This is not my primary, snow remover so it should last a while.
The BX5455 HD is next…I hate to be unprepared.😊
7,029
I’m central New York.
I don’t have a date certain but November 1 is likely a typical date for me. I really don’t like putting chains on in very cold weather.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
When I ran a blower I would always prep/test run it in Nov. Whether it stayed on or not, depended on what other, if any, chores I needed the tractor for.
Mowbizz
Bx25d
Aug 19, 2021
553
314
Wow! In my opinion, the job of installing it is pretty tough so once on and running, it STAYS on until April!
9,308
I have two tractors which eliminates the "stress" of when a tractor is set up for winter use, but it's not a struggle to get the hydaulic angle blade (SSQA) on the front and the snow blower on the rear of the MX. I have to connect six hydraulic lines, a pair for the snow blade and two pairs for the blower but that's easy enough.
Getting the front snow blower on the BX25D was more of a pain than getting both implements on the MX. At least I don't have to crawl around on the ground with the MX or remove the FEL. 😂
Mowbizz
Bx25d
Aug 19, 2021
553
314
You can say that again! BX25D here too.
9,308
I had a BX25D for five years. I always seemed to be playing catch up in terms of getting it set up for winter. Typically it would be snowing and freezing cold as I removed the FEL, installed the snow blower quick hitch and subframe, and wrestled with the mid PTO driveshaft. I think I left it as long as possible because it was a fair amount of work to set up and there was always the chance that I'd need the FEL for something.
I don't miss those days, and I have to say, life is so much easier with the MX.
7,029
I've had the BX2360 for 11 years now.
I typically have the FEL on early spring and fall when I'm not mowing.
If I don't need the FEL, I'll go right from blower to mower, and visa versa.
Like @mcmxi says, it has gotten to be more challenging putting the blower on as I get older.
Same with the MMM. I could easily see myself looking at a rear finish mower down the road.
It's still the tire chains that motivate that task while it's above 40-50 and sunny..... ;) If you've ever put on icey/snowy chains on, you know what I'm talking about.
Our extended forecast has some sun and 60's. I can foresee one last trip mowing/chopping leaves, and then transition to winter mode. ;)
5,153
Early snows don't last, so Thanksgiving is my date. I still haven't done my 200 hour service and I am about 30 minutes late.
BAP
Dec 31, 2012
3,010
1,110
I wait until there is actually snow in the forecast and looks like enough to need blowing. I put my blower on and take off several times throughout the winter because I use my loader a lot on my B2920. I can swap from loader to snowblower and vice versa, in about 15-20 minutes. Tire chains, I wait until it looks like I need them.
Mowbizz
Bx25d
Aug 19, 2021
553
314
Did my swap over to snowblower today (nice dry warm day). Before that, I moved my sand barrels into place and filled them with sand…last season, I forgot this step and had to huff barrels, stands and sand by wheelbarrow. I won’t forget that step again! Saw this morning that there IS snow in next week’s forecast…I’m ready.😊 JUST DO IT!! 🤣
7,029
Posted on “what did you do today” thread….
Chains will follow next couple days.
