Dust ejector source
borgunit
L3600GST
Jan 12, 2011
14
Bluffton, OH, United States
I have a L3600GST tractor and wanted to buy an dust ejector valve. Kubota wants over $110 for a complete assembly housing which includes the valve. Would anyone know of an alternate one that would work? The id is 30mm (1-1/4") or close to it. Thanks
Workerbee
Zd21
Mar 1, 2020
292
147
MN
Ask your Kubota parts guy. I have bought some through the years from Kubota. If I remember right the last one was about $7.
8,628
Do you have a single element air cleaner or dual element?
Single air cleaner:
Cap assembly
Possibly this valve?
Dual air cleaner:
borgunit
L3600GST
Jan 12, 2011
14
Single air cleaner:
Cap assembly
Dual air cleaner:
It is a single element filter
6,480
Actually that Inner diameter is 1-1/2" inch. Too large.
Don't make a mountain out of a mole hill!
You can go to Amazon and order various sizes to fit whatever your need is. You do have computer access since you have demonstrated it's use here. :sneaky:
borgunit
L3600GST
Jan 12, 2011
14
That actually is not true. I have been searching. There are lots of variations but without dimensions, how can someone find what fits. I have not found one yet that is not too big. If you know of one, i would appreciate a link to it. Thanks
6,480
See post #5. Go to bottom link and order. It states it fits your tractor. If you think it is loose just put a small tie strap around the neck.
5,607
just checked, the one on my BX23S is 1.5", cost is $3.50 CDN..
could wrap some rubber( bicycle tube ? ) on your air cleaner then clamp mine onto it ?
whole lot cheaper than those epay ones !
