Oil pressure light on
biglbft
Kubota B2650
Jul 20, 2024
Montvale NJ
While working with my B2650 the oil pressure light came on and off a few times intermittently and then shortly after the tractor just died. There's plenty of oil in it. Any thoughts
2,864
hours on machine?
filter changed when?
07wingnut
262
109
Clearwater, BC, CA
How did it die? Suddenly, or slowly, like it was under load (ie oil starvation). The two incidents may be unrelated. Get mechanical oil pressure gauge that you know is good and install it. You should get oil pressure just from cranking the engine, even if it doesn't start. If you observe pressure, the stall issue may be something else like fuel starvation.
5,648
I agree - don't jump to premature conclusions.
The oil pressure light may have flickered because the engine was faltering.
TECH101
Kubota - Bobcat - Caterpillar - Case - John Deere - FARM - CONSTRUCTION -
Mar 8, 2022
72
I would test the sensor, if faulty the machine will not start
3,252
1,675
The B2650 tractor will start and run just fine with the engine oil pressure switch unplugged. Its only function is to turn on or off the oil pressure light.
9,161
Yea I was a little baffled by this statement too.
3,252
1,675
Unplugged..... yes, it will run
Also, plugging into a faulty switch will not affect whether it will run.
There is no connection between the oil pressure and the fuel-shut-off solenoid.
