Battery not charging
newshb_k
Jordan
Hi
I have kubota b7100 (none-HST), and the battery doesn’t charge; even with high revs
if I remove the battery cables after starting the tractor, it will keep running.
The battery is almost new, so I suspect it could be bad wiring, and not sure if it is the regulator
I took a look on the wiring diagram, and I am planning to check the wiring from the generator to regulator, then regulator to switch, and then from the switch to engine/battery
Is that what I am supposed to check 😅
8,743
You will need a multimeter and set it for AC, disconnect the 2 wires off the generator / Dynamo.
Connect the meter to the 2 wires off the gen /dyno and run the tractor, you're looking for about 15 VAC in idle and about 30 VAC full throttle.
newshb_k
Jordan
thx
so I disconnect the 2 wires of the dyno when tractor is off, and once I connect the meter, I start it and see the reading?
Also, since the tractor keeps running if I disconnect battery, doesn’t this mean dyno is ok?
8,743
No, diesels do not need electric to run, they make the heat to fire off of compression not electric.
2,831
AS Wolfman said - the battery serves only one purpose there - TO START the engine - once running the battery simply sits there and get charged in a perfect world.
SO - the two wires - get your meter and set for AC - and then use a clip or get someone to hold them on the two leads, it DOES not matter what wire to red or black leads - fire up the tractor, there should be a reading of AC voltage - and slowly rev it up, the voltage should climb WITH the rpms. As mentioned, at near WOT you should be getting upwards of 30 volts AC.
NOW - if that checks out - the next part of the puzzle would be the VR - voltage regulator, that little box flips the AC back to DC and charges the battery.
The chances of the Dynamo being bad are very slim - it is such a simple device that it can almost never be bad - ( could have a broken wire)
Does your B7100 have 4 bolt front wheel or 6 bolt?
newshb_k
Jordan
Thanks a lot for the detailed answer, I well check the dyno, and proceed forward in troubleshooting
mine has 4 bolts front wheel
