Hydraulic Requirements for Sabre Samurai mower
PHPaul
Apr 2, 2015
1,145
1,254
Downeast Maine
www.eastovershoe.com
Hi Dave,
Did you use 1/2 ID hydraulic hoses for your hookup of the Sabre cutter?
On the off chance that you meant to reply to me, no, I didn't. The rest of the tractor is plumbed with 3/8ths IIRC, so there didn't seem to be much point.
David K
Kubota M6800
Mar 3, 2024
Kentucky
I have had a Samurai cutter for a number of years.
Do not buy without the breakaway mount
On a M7040 I used a pressure balanced flow control to get the cutter down to the recommended speed and because I had an industrial strobe light I used it to verify the speed.
Do not just clamp it to the side of your bucket as it will bend it.
I used heavy pieces of steel plate between the cutter mount and the bucket after I noticed the bending.
Hi Dave,
Did you use 1/2 inch ID hoses for the hookup of the Sabre cutter on your M7040 or just 3/8 inch ID hoses for the hookup?
Carey
United Kingdom (Wales)
Hi Everyone
i am in the Uk and know nothing about agricultural equipment. I do possess an old Alice Chalmers Simplicity with a bucket and hydraulics.
Would this samurai work on such a machine. Perhaps some of you 'small kubota' owners might know of this older tractor ? Samurai seems a useful piece of kit. I have fairly not challenging hedges to cut.
Also, who is the manufacturer and how would I contact them ? At present I have only seen a dealer in Canada
Cheers Anyway
Carey
Canadian Agri Tech
Sabre Samurai
Jan 29, 2025
Hi Carey, apologies for the late reply we don't check these forums very often. Hop over to our website www.cutthat.com we sell worldwide from our online store and would be happy to send one to you. You can fill out our contact form or give us a call if you have any questions, I would need to know what exact model Alice Chalmers tractor you have to confirm if it would work. In order for it to work your tractor just has to produce a minimum of 3.5 GPM (gallons per minute) and 2,000PSI , if your tractor is 24HP or more than it should work.
Regards,
Canadian Agri Technologies
