Kubota b8200d
lakemathews
B8200d Kubota tractor
Mar 9, 2024
14
Calif
Hello everyone
Was wondering if there is after market hydraulic cylinders for my loader on my b8200d
3,430
Doubtlessly there are “generic” cyls which will replace the OEMs…. (and of course, your loader model would likely be more descriptive than your tractor model.)
5,224
Hi Dan, Keith here
300 loader and I would like to replace all of them
If you can take a few measurements I will try to point you to some sources. Also a picture of the cylinders so I csn see the construction as well.
Measurements for Bucket and Boom Cylinders
Cylinder bore
Diameter of rod
Diameter of pins
Retracted Length center to center of pins
Extended length pin to pin
lakemathews
Mar 9, 2024
14
Calif
Cylinder bore
Diameter of rod
Diameter of pins
OK I'll get busy
lakemathews
Mar 9, 2024
14
Calif
Cylinder bore
Diameter of rod
Diameter of pins
Good morning Dan
Here are the specs
Bf300 loader
17.9 inches reach (dumped)
45 cm
47.4 inches reach (ground)
120 cm
23° rollback
79.1 inches height (at pin)
200 cm
64.4 inches clearance (dumped)
163 cm
boom cyl: 1.77 inches
4 cm
boom rod: 1.18 inches
2 cm
bucket cyl: 1.77 inches
4 cm
bucket rod: 1.0 inches
2 cm
5,224
Good morning Dan
Here are the specs
Bf300 loader
45 cm
120 cm
23° rollback
200 cm
163 cm
4 cm
2 cm
4 cm
2 cm
You are missing pin size, retracted length and stroke for the cylinders. Those other dimensions are not needed for sourcing cylinders.
5,224
Good morning Dan
Here are the specs
Bf300 loader
45 cm
120 cm
23° rollback
200 cm
163 cm
4 cm
2 cm
4 cm
2 cm
Based on dimensions I found in an older thread these should be a direct drop in replacement for the lift cylinders. The bore is larger (2" versus 1.77") so you will gain 28% more lifting power.
I suggest you double check all dimensions before buying.
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
319
169
Eastern PA, USA
My hydrualic hose shop rebuilds cylinders for a third of what I could buy a replacement for. Have done a couple on various machines. I just take in hoses or cylinders and in 3-4 days time, I have new ones.
Might be worth checking out.
lakemathews
Mar 9, 2024
14
Calif
Ok
The boom cylinder od is 2.19
The boom piston is 1.18
Do you know the part number for the lift cylinders
Thank you for that info
5,224
Ok
How do you arrive at 1.18 diameter piston? That is the rod diameter which would be tough to do on a double acting cylinder.
The bucket cylinder kit is right under the boom kit in the link. They are ~$75 per cylinder.
lakemathews
Mar 9, 2024
14
Calif
OK Dan,
Rod is 1.18
Bore is 1.2
Retract is 29 inches
Pin is 1 inch
Pin to pin is 27 3/4
5,224
OK Dan,
Rod is 1.18
Bore is 1.2
Pin is 1 inch
Are you confident of those numbers? I am not.
Bore @1.2" is simply not plausible - way too small. Plenty of sources say 45mm (1.77") which is consistent with the OD number you posted earlier.
How is the retract number measured and how does it differ from pin to pin? Was the cylinder fully retracted or just to the point the bucket was on the ground?
What is the pin to pin center spacing with cylinders fully extended?
