Replacing Fluid level sight glass
TomD406
L2500
Feb 11, 2024
Helena, Montana
I have a sun baked 1999 L2500, new to me with only 360 hours. The Fluid level glass is clouded and not functional. I see a part number listed and have done a quick review of the WSM but did not notice a procedure for changing it out. Suggestions, advice. Thanks
4,267
Paint over it and it won’t bother you so much.
old and tired
1,919
1,297
Not much to changing mine when it cracked, I drove it up a side hill keeping the sight glass on the uphill side ;) and it just unscrews. New one screws back in.
If you don't have hills, I'm sure jacking up the tractor onto it's side should work...
3,092
The hillside is the trick - and careful not to get "stuff" back in the open hole as you place new back in.
TomD406
L2500
Feb 11, 2024
Helena, Montana
Got it! And as usual, I should have looked at the past posts more closely. There are 3 or 4 other posts about this that clears it up. Thanks for the reply.
11,311
Your sight glass does not screw in it pops in the hole.
I would use a little RTV (silicone) or anaerobic sealer if you have it.
Put it on the grommet to case surface of the grommet to seal.
