3 point question
4,056
Now maybe I missed it in the book, I dont know but I stood that bitch up on 3 wheels again this after noon, and yes I have showered and changed my shorts !!!!!! OK so I was using the bucket to try and unroot an old apple tree, and in the process managed to get the one rear tire off the ground bout 12 inches of so,,,, it felt more 5 or 6 feet. So the question stands is there any way to lock the 3 point from the MMM, no I didnt remove the mower this year I just figured that weight slung low would work for snow we never got. So is there anyway I can put the weight box on and not have to worry about it going up and down with the MMM ? Anybody ?
GrumpyFarmer
4,000
Maybe I am not much help…I am chuckling at the story…it happens welcome to the club….but I guess are you asking about the 3pt hitch or pinning the MMM deck in up position? To me those are 2 different things so I am not sure what asking the way it was worded?
My B does allow to pin the deck up…go to manual(s) to me would be easiest way to see / check. In the up position there are holes on the arms that hold the deck and it can be pinned (pins were there for me). maybe different on yours but I assume similar.
unless I am not understanding though, raising deck will not keep tires on the ground….i believe it could be pinned up if similar to my B.
sorry if no help.
keep the rubber side down.
4,056
I dont think the 01 series has anything like that, BUT , I will look again sometimes I dont see what I see
8,745
So for clarity:
You want the deck to stay up with the ability to use the three point without the deck dropping?
Or
You want to keep the three point pinned up?
JimDeL
Aug 31, 2022
359
401
Austintown, Ohio
Raise the MMM, then turn the mower height dial (it's more or less just behind your left foot) to "Top" position." The MMM will stay up, and the 3PH will still operate.
GrumpyFarmer
4,000
First check your manual(s) but then look at you deck does it have a u/v bracket on the front on each side see pick below (should have a pin hole? If so run it too very top and see if it aligns to a hole…check and see if manual suggests pinning the deck up from that location.
4,056
What I want is the 3 point to stay UP and still use the MMM I cant find anything in my search so maybe not
4,056
So for clarity:
Or
Yes keep the 3 point up that way the weight box doesnt drag when I mow if that makes any sense
4,849
I don’t know anything about your specific tractor so don’t know if it has a function that allows pinning the 3 point up and leaving the MMM mobile. If it does, that’s probably the preferable method.
I do know I have a thing on the pegboard we used to use for pinning up the 3 point on our old 9N. It was just a kind of longish toplink pin with a short chain permanently attached to the head end by way of a repair link that had been beaten around it. Hook the other end to some part of the implement (preferably somewhere in the vicinity of the middle) or a lift arm on the back side of a side link (maybe not ideal, but works).
If that doesn’t make complete sense and you’re interested in what exactly it is, I’ll take a pic or two next time I’m in the same building with it. Haven’t used it in a few years and no longer have the 9N but about 95% sure I know where it is.
Even if you don’t do exactly that, basically chain it up to something.
6,876
Skeets- the BX tractors have little “tabs” to pin/hang the side lift links to, but don’t know if the same applies to the B’s.
You should have them on your BX2360 because I do. Just don’t know if you have them on your B.
Disconnects the side links from the rock shaft, etc. They just hang from the tabs.
That would keep the 3PH up and let you raise/lower the MMM.
JimDeL
Aug 31, 2022
359
401
Austintown, Ohio
Okay, now that you've clarified your need, I have a BX2380 and there are holes in the rear frame that allow pinning the 3 point up.
The problem is that it involves disconnecting the lifting arms, meaning you'd need to somehow jack the attached weight box up far enough to allow making the connections.
That's the only way I can see it working for you.
8,745
Some are saying there are support or holes to do it?
I would have to see one to know.
Someone want to supply a picture?
I just went and looked at several picture's and I'm pretty sure those holes are for tie downs and not meant to hold the three point arms up.
All the units I know of, you can not PIN the three point arms up.
edritchey
Ferris IS800Z - New Holland WM75 - John Deere X500
Jul 19, 2014
1,119
823
Wellsville, PA
It's not going to work Skeets the place the lift arms pin to is just a storage place to lock the 3pt arms to that keeps them up but will allow you to still use the MMM. It would be to high to have anything on the 3 point.
edritchey
Jul 19, 2014
1,119
823
Wellsville, PA
4,056
The BX has 2 places you can attach the 3 point arms the B2601 doesnt. The 3 point arms and the MMM are using the same levers, to raise and lower on both the BX and the B, I think the big B's now the 50 series had something different, So maybe I am just wishing here,, thanks for all the input
dan’s kubby
BX23S, B2672 snow plow, Land Pride SGC0554 Grapple, Titan 4306 Gra
Feb 8, 2024
NE PA
Be careful with the belly mower on. If you end up sliding on the mower deck it acts like skis. No reverse traction will stop it.
3,215
Sorry for the stupid question skeets, but how difficult is it to just remove the weight box, and put it back on when you need it?
Maybe I missed the point. But I assumed that if you were concerned with the weight box moving with the MMM, and that you were concerned about using the MMM...and the weight box dropping against the ground when using the MMM...
Seems like for the application you referred to, the height of the weight box would have little affect on the effect it has on holding the rear tires on the ground.
Side slope it would...but you were not referring to side slopes...
Edit: I think I may have expressed my post bassackwards, but I guess I don't see the relationship. Your rear tires lifted off the ground and it was uncomfortable. Was the weight box on the tractor at the time? Maybe that was the point I missed...
Easily confused here...maybe a western PA thing? LOL
