B6000 PTO reverser for sale
Mikeschaller
B6000
Nov 18, 2023
Ontario
I bought a tractor for the engine, it had the reverser on it and a finish mower. I won’t used it. I have other tractors to bush hog with. My B6000 is just a toy to piddle with and I’ve had it 20 years or so.
Is it a 4wd tractor? Would you be willing to part with the pro shaft as well? Mine is an 18 spline.
Mikeschaller
B6000
Nov 18, 2023
Ontario
Parts tractor is a 2wd and everything is for sale.
wish I had found you a few months ago, I just spent a fortune completely rebuilding the transmission. Unfortunately I don’t think the pto shaft will work in a 4wd unit, but out of curiosity, what do you want for the reverser and shaft?
9,200
I think your a little confused, there is no difference in the Tractors PTO shaft for a 2wd to a 4wd.
His PTO spline is an 18 spine out of the tractor into the gearbox and 540 standard 10 spline out of the reverse gearbox.
Mikeschaller
B6000
Nov 18, 2023
Ontario
There is a difference between the 2wd and 4wd shafts, take a look at the transmission parts diagram. I have a gray model that came with an attached tiller, not 3pt, and has an 18 spline output to match the tiller. Us models had 3pt attachments and a 10 spline output.
