krw1103
B3200, M6060, LA1154 Loader, 60" LP box blade, 120" land grader, Cat 307 Exc
I recently installed a hydraulic top link onto my M6060 for finer adjustment when using my land leveler blade. It is a fairly heavy implement which is 10' wide and 54" long and has a lot of weight to the rear of the implement. i have not put it on a scale but my estimate is around 1600 lbs. The 3 point lifts it without any issues but when I use the hydraulic top link to lower it the chattering and vibration are shaking the entire tractor roughly. the top link cylinder came from sparepartsholland.com and I have been communicating with them about the issue. The cylinder has integrally mounted pilot operated check valves and I am wondering if the weight of the implement is causing the POCV to close after trying to lower and causing a hydraulic shock to the system. it is a rapid action and sounds like an automatic firearm with the fast repetition.
Has anyone else had this kind of problem and if so what did you do to correct it.
