B2650 B2660
5,152
Kubota B2650 (50" SNOWBLOWER)
Kubota B2660 (60" SNOWBLOWER)
Kubota B2400D (4wd)
Kubota B2400E (2wd)
Will B2660 snowblower off of a B2400 mount on B2650
Your question makes no sense to me. You are asking if you can put one snowblower onto another snowblower. All that I can think of is if you want to know if one snowblower (B22650) will fit in place of the other snowblower (B2660) and which one will fit your tractor. You need to find out what the mounts (kit numbers) are for both snowblowers and then determine if they are the same. Then you will need to determine if either of the mountings is correct for your tractor. The other thing you will need to know is if the frame from the tractor that a particular snowblower is coming from is the same frame as your tractor. I have no idea if your tractor is 2 or 4-wheel drive. Have you considered asking your Kubota dealer?
BAP
Dec 31, 2012
2,941
1,052
Kubota B2400D (4wd)
Kubota B2400E (2wd)
Dusty, I think you need another cup of coffee before answering this. I believe that the OP is asking if a B2660 snowblower that was on a B2400 previously, will be able to be used on a B2650 tractor. Pretty simple question, I unfortunately don’t know the answer but I am sure that someone on here does.
5,717
well it is confusing... Kubota should NOT have the same part number for BOTH a tractor AND a snowblower !
'B2650' is which the tractor or the snowblower ?
5,152
I’m new to Kubota equipment and did know there was a blower with same number!
I looked up the numbers that you gave, and that is all that I can tell you about what came back from the search engine on the Messicks dot com website. That is why I highlighted the numbers. I still believe that the only one that might be able to answer the question correctly is either a Kubota dealer if they still have the original literature on the products or Kubota Corporation. I am relatively certain that they also will have to research the question. You might try Messicks and if there is someone there that has been around there for the past 20 years they might know.
