Yeah, which one did you buy. I am thinking about getting a P2P one for getting better reception at my gate.What one did you buy???
TP-Link EAP225-Outdoor AC1200 WiFi Gigabit Indoor/Outdoor WirelessYeah, which one did you buy. I am thinking about getting a P2P one for getting better reception at my gate.
drive.google.com
WiFi will not go 600ft (reliably) With my steel buildings I ran fiber optic to my shop 175'. (Buried 1.25 conduit) Used a media converter on each end to turn fiber into a 1gb port. Put a switch and access point in the shop. If you don't have an ethernet port on your Starlink get one, great for testing and adding on wired devices. Make sure to set up the AP in the BnB as a guest network and it will keep any guests from poking around on your devices.Let me see if I'm on the same page with you "techies". If I bought a Starlink system I would need to buy another router and a mesh network to send wi-fi to my AirBnB about 600ft away???
How far will it go reliably would you think???WiFi will not go 600ft (reliably) With my steel buildings I ran fiber optic to my shop 175'. (Buried 1.25 conduit) Used a media converter on each end to turn fiber into a 1gb port. Put a switch and access point in the shop. If you don't have an ethernet port on your Starlink get one, great for testing and adding on wired devices. Make sure to set up the AP in the BnB as a guest network and it will keep any guests from poking around on your devices.
There are lots of factors, anything over 100' is great. Put a couple of walls in between and you cut that in half. Metal siding and you loose ~90% of your signal. Easiest install if you have a line of sight option would be a point to point WiFi extender: Amazon.com: 5.8G Wireless Bridge PTMP WiFi PTP Point to Point Long Range Outdoor Wireless Access Point Extender Network CPE 2KM Transmission Distance with 12DBi Antenna 2 LAN 100MBps 24V PoE Power Supply 2 Pack : ElectronicsHow far will it go reliably would you think???
My EERO goes about 600 feet with very few issues. However its just running a gate controller and one ring doorbellHow far will it go reliably would you think???
Please look at my recent post of my P2P problems in a new thread. Any ideas would be appreciated.There are lots of factors, anything over 100' is great.
