LA805 Hard line
3,156
Go to Kubota USA dot com and illustrated parts list by using this link
argee to terms and conditions then search for the LA805 model number and go to the hydraulic section then the tube section (as shown below). Figure out what you need and then search for the part number on the internet or have the dealet order it for you.
7,352
Hello
I seem to have worn a hole in my front loader hardline. It’s a LA805 loader. The metal line is the second from the top and I can’t seem to find the part number for replacement. Any help would greatly be appreciated.
Two of these and a foot of new steel line. Less than $20 and a scant 30 minutes work.
7,717
Make sure the line is located correctly with rubber bushing under clamp. A steel line should not be getting wore through.
Madriding1
L3560HST
Aug 27, 2023
Colorado
I agree. It appears the line was somehow rubbing on the bracket screw. It’s a low hour tractor (254 hrs) so I was pretty surprised to see the leak. I’ll definitely make sure the clearance is there when I reassemble. Thanks!!
7,352
All of my loaders and tractors clamp the steel lines with steel clamps. No.padding and no "clearance". I suspect your clamp was loose allowing the line to move about and fret.
Jchonline
600
Red Feather Lakes, CO
Hello
Before you replace it you need to figure out how you wore a hole in it and fix that first!
Update sorry I read the OP and didnt read all posts. Disregard!
