Thanks to North Idaho Wolfman for correct manual. Reviewed it this morning.
Basically still at same point. We have verified the safety switches are sening correct signals to OPC so tractor should crank (but doesn't). The way we checked signal (voltage) to starter is to put multimeter on wire that connects to OPC and then to blade on starter. With key to start, still no voltage on it. We checked continuity from OPC connector in dash down to connector on wire, all good.
Going to trace wires again and look for anything like pinched etc but about ready to just jumper start switch past OPC.
As i mentioned if you hook remote start switch to starter solenoid starter cranks fine and tractor starts fine. I mowed 5 acres yesterday with no issues.
