Dark oil
t&j
LX2610
Apr 18, 2023
Spirit lake Idaho
I did the 50 hr. Oil change and am at the 100 hr. mark and the oil seems to be darker then I would expect. Normal or Not?
3,537
When I do an oil change, I think the new oil is black after 10 minutes of running.
FreezinGator
BX1500 LA181 FEL 48MMM Back blade
Jul 10, 2020
58
Upstate NY
Diesel oil gets dark faster than gasoline engine oil. I was surprised at first too. As long as you are using the correct weight diesel oil made for diesel engines you are good.
5,375
I concur with the above....perfectly normal on diesel engines.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
316
137
Jefferson, Ohio
On my L3540 and my ZD1211 the oil gets dark real quick.
My L4060HSTC with 100 hours on the oil it is not real dark yet. My theory is the tractors with emission control have less ring blow by.
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
107
sheridan
An old friend of mine, whom survived being a tail gunner in WWII, was an old time diesel mechanic one told me that diesels make oil, thus turning crank case oil black real quick. That was probably true for older diesels before regins, dps and all that crap.
rr
lynnmor
B2601-1
May 3, 2021
1,800
1,605
Red Lion
rr
I think you will find the newer engines with regen is far worse. Making oil is simply dilution of the motor oil with diesel fuel, engines that push the extra fuel thru the cylinders to regen causes oil dilution and black oil. The clowns that turn the air black with their deleted emission systems usually have cleaner oil.
Biker1mike
Jan 11, 2022
1,174
1,275
Gallatin, NY USA
I swear I could do an oil change and then drain without running the engine and the oil would be coal black. Life with a diesel.
Seane1987
LX2610SU TLB, BX2350
Jul 18, 2021
61
54
Lafayette NY
Any engine with EGR will have black engine oil relatively quickly after an oil change. Most of the engines that I work on daily have no problems with fuel dilution (cummins and detroit). I am sure kubota is similar. A non EGR engine will keep the oil "looking" cleaner. An oil sample is the only real way to tell oil quality, I have seen some really crummy looking oil samples come back with better results than oil that looks good. The engines I see daily can have jet black oil almost immediately after it goes in and gets run to recheck the level.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
I did an oil change at 73-74 hours and the machine now has 78 hours.
Like Texas Tea now. Black as a vampire bat. 🦇
LOL
Dat's life !
t&j
LX2610
Apr 18, 2023
Spirit lake Idaho
I have an LX2610, so I'm under the hp requiring re-gen. First time owning a diesel. Thanks for info.
5,515
2,226
the diesel engine creates soot. Some of it gets by the rings which is normal. Then it sits in the bottom of the pan, also normal. Draining it won't get all that stuff out. So when you put new oil in, it mixes up with the stuff laying in the bottom and then you get black oil. Perfectly normal. Only remedy is to pull the oil pan off and wipe it out which IMO ain't even worth doing.
t&j
LX2610
Apr 18, 2023
Spirit lake Idaho
That makes sense, it's hard enough getting the oil filters off in such tight space. Oil pan can stay on. Thanks for the information
