Leaks from both pivots on front axle steering?
493mike
Front loader, front snowblower, brush hog, tiller, back blade, soft cab, roller.
Sep 18, 2017
White Cloud, MI
I recently noticed leaking on my B2920 front axle. Where can I find a parts diagram/part numbers to repair this?
Mike
493mike
Sep 18, 2017
White Cloud, MI
Will have diagrams as well as current part nos. Sometimes part nos. are superseded.
Thank you for the site address. I'm no computer guru and can't open the PDF (it is grayed out) under the Help tab to allow pop ups? Could you guide me please?
Mike
old and tired
L2800 HST; 2005; R4
Mike
Mike, the link should not be a PDF.... you should see after clicking on the link what's in the photo below...
Is your tractor a B2920HSD? What serial number is your tractor... depending on the SN is which seal to buy.
2,041
Mike
Go to the Kubota USA dot com website (I typed it out but use normal format or search)
then select illustrated parts list
then select the agree to terms box
then search for your tractor model and then find the correct section to look at (front axle)
Tioga Tim
B2620
Nov 11, 2020
42
Upstate New York
Mike
My 2620 was leaking on one side. I topped off the resevoir with heavier gear oil and that seemed to take care of the problem. I was running the Kubota 30 wt per the manual -thought that seemed pretty light to begin with.
Tim
493mike
Sep 18, 2017
White Cloud, MI
Thanks for the responses fellas! I found the seal and correct P/N. It appears i need to remove the 4 bolt flange holding the bevel drive to the axle housing to accomplish the disassembly to replace the seal.
Mike
BAP
Dec 31, 2012
2,927
1,040
