Hydraulic Maintenance Question
Sparky Prep
177
245
South Florida
So, as many of you might have read, I am soon to get a new Kubota Tractor. I already own a 3 point mounted log splitter that gets power from remotes. The log splitter was given to me by my dad. It is in like-new condition, BUT, it has not been operated in probably 10 years, since my old Ford tractor didn't have remotes. Would it be prudent of me to somehow drain all the old hydraulic fluid from the log splitter, before connecting it to the new tractor and operating, thus mixing 15-20 year old hydraulic fluid with the new fluid in the tractor? Any advice would be appreciated, and thank you in advance.
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
Yes, drain every hose and cylinder, get as much as possible out, as you do not want to mix fluids. Maybe even drain and then rent a Kubota tractor to split a few logs(to get all the old fluid out).
3,485
Purge the cylinder by extending it with the return hose disconnected and you will be good to go.
Powering it off a remote valve is not the best way to hook it into your new tractor..
4,136
hmm....'sat for 10 years'......
For sure ,if possible, find some other tractor and TEST the logsplitter, before hooking it up to yours. Unless hoses were capped, wasps or spiders probably made their homes in there. At the very least, remove the hoses ,inspect and clean them. Also manually cycle the ram ,several times, to extract as much old oil as possible. You could rig compressed air to gently help purge the cylinder and valve.
The cleaner it is, the less chance of contaminating your tractor's hydraulics.
3,485
Lets try not to get too far out over the skis..
Its a 3pt splitter. Presumably it has hoses with quick connects on it. No spiders or wasps getting in. Typical 4x24 cylinder holds just about one gallon of hydraulic oil , hoses and valve another pint. Take the coupler off the return line, extend the cylinder, and there wont be much more than a cup of residual oil in the system. Thats nothing when hooked up to a tractor that holds 10.6 gallons.
4,432
Now that's a good solution. You don't want the old hyd oil in your Kubota, but it's OK to rent a machine and put it in there. Your character is being displayed!!
Southern Smoke
'22 Kubota L2501 HSD/ Loader, Tiller, BushHog, Box Blade, Forks
Jul 18, 2022
Loxley, Alabama
D2Cat,
I too, was a little taken aback to see the suggestion to use a rental tractor in this manner. We are supposed to be better than that...
cthomas
LX2610 HSDC
Jan 1, 2017
863
572
La Farge Wi
My local rental place already uses universal hydraulic fluid in their equipment so what is the issue? This is also the place that starts the pressure washers with no water hooked up to prove it runs before renting it. I worked at dealerships were people would come in to "test drive" a new pickup and a few hours later it would come back with scratches in the bed and the remains of whatever they hauled(gravel, mulch, compost, etc.). This is the same rental place that come in with a newer gas truck with the complaint that the diesel nozzle would not fit into the fill tube for the GAS tank. And he was determined that some diesel would clean the pistons to prevent misfires.
2,441
1,255
My local rental place already uses universal hydraulic fluid in their equipment so what is the issue? This is also the place that starts the pressure washers with no water hooked up to prove it runs before renting it. I worked at dealerships were people would come in to "test drive" a new pickup and a few hours later it would come back with scratches in the bed and the remains of whatever they hauled(gravel, mulch, compost, etc.). This is the same rental place that come in with a newer gas truck with the complaint that the diesel nozzle would not fit into the fill tube for the GAS tank. And he was determines that some diesel would clean the pistons
If SP did take your advice, he'd just be replacing one volume of suspect fluid with another.
