ThanksPaulIs it one of these: https://www.tractordata.com/farm-tractors/008/1/5/8157-kubota-l1-18.html?
It's a 1.3L 3 cylinder. In that sense an L2501 is probably closest. It looks perhaps like an early L model.
But actually, you're looking for a fuel filter.....so I'd just get a fuel filter for that model. It looks like maybe a grey import, I don't see a parts list on Messicks for it. Someone else may be able to help with a diagram.....but I'm guessing a fuel filter isn't something that needs to be that specific to the model, probably the fuel filter off an L will work.
bonjourLooks like the OP is located in France…
Are you trying to find replacement parts like the fuel filter?New to the forums here.
Kubota Sunshine L-18 help please. Which modern Kubota is nearest to it? Is fuel filter easy to replace?
Please keep answers aimed at dummy.
thanksAre you trying to find replacement parts like the fuel filter?
If you are you would you wouldn't cross to new tractors, you would cross to a model that wqas more common during the came time frame.
Parts from that would be very similar to a L2250 which uses the same engine and is of the same time frame.
Is the hydraulic filter a spin on or cartridge?Thanks for all advice so far
Found the filter kit I needed on Shop4Trac.com.
Fuel filter replaced successfully and now running like a dream again.
Air and Oil to change next!
Hydraulics may be a challenge. Any advice out there ?
Looks like a cartridge.Is the hydraulic filter a spin on or cartridge?
Yes on that style it's best to drain it first.Looks like a cartridge.
Do I need to drain the whole hydrolics?
