How heavy
bonham
b7001
Jul 31, 2011
England
I have a B7100 with a loading shovel mounted.
What is the lifting limit on the bucket please?
I fancy lifting 1 tonne bags of logs with the bucket but dont know if it will lift the full capacity of 2200 lbs.
Any advice would be helpful.
Thanks in advance.
kuboman
721
Thanks in advance.
A B7100 lift a tonne, it would one heck of a b7100 to lift half that more like half that.
G-Man
B7500, ZD221
Jul 27, 2012
81
Excelsior, AR
Is there a model number on the side like LA272 or LA302? If you multiple that number by 2.2 and that will give you how much weight the FEL can lift. I have an La272 and can lift about 600 lbs so 2,000lbs is way out of thw question for your tractor. Your tractor probably weights about 1,500 lbs.
mendonsy
B7500HST/LA302
May 28, 2012
357
34
Mendon, NY
I agree!
I have an LA302 on my B7500 and can just barely lift 700# with my forklift that replaces the bucket and is at least 50# lighter than the bucket.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I think the 7100 lift capacity would be more in the range of 400 - 500lbs.
A M7040 loader is rated for just over 2500#.
3,097
I have a B7100 with a B219 FEL and the FEL manual states a 500 pound max lift capacity.
3,097
Never heard that before, but 219 X 2.2 = 481.8...... pretty close.
kuboman
721
As a rule of thumb with Kubota you multiply the model # by 2.2 which is lbs/kg to give you a crude lifting capacity of the loader.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
Ok so where did this rule of thumb come from? It's the first time I've heard of it. What's your source for information of the model number multiplied by 2.2??
Sledge
B7001, Big B 4ft topper
Sep 17, 2012
37
Gloucestershire UK
Maybe Kubota number their buckets referring to its max capacity in kg?
I agree with other comments, can't expect a tractor to lift more than its own weight.
bonham
b7001
Jul 31, 2011
England
Thank you for the replies.
I had no idea of the lifting capacity.
If 500lbs seems to be the consensus of opinion the 1/4 ton would seem to be the limit.
The idea of shifting the logs obviously needs a rethink.
Now where is that telehandler on Ebay.:D
Wild and Free
B2150 HSD w/Case L340 fel 68" quicktach bkt, 60" jinma snowblower, box scraper
Oct 25, 2012
390
North Dakota
Another thing to keep in mind is where Kubota rates the weight capacity at.
Most manufactureres rate the lifting capacity at the pin where the bucket mounts to the loader arms "I would assume kubota does too". So take the rated weight and reduce it as the load progresses out away from the pins. I am sure there is a simple formula to figure this if one looked.
kuboman
721
If you go to Kubota.ca there are some very good specs on current loaders and they give the capacity at both pivot and bucket bottom.
