What is the best way to get starter out of BX1500?
O'boy
BX1500
Jul 9, 2020
41
My starter is bad so I ordered a new on. Where it is located it looked, at least from the top, to be an easy fix. I took the front off and now it doesn't look quite as easy. Would I just take out the dynamo to make room? That piece blocking it is bolted on in 6 places, two of which are behind the frame.
8,745
Wise acre answer... Unbolt it. :ROFLMAO:
Two nuts and bolts hold the starter in, take those off and, once unbolted you should be able to pull the back side of the starter up and out.
O'boy
BX1500
Jul 9, 2020
41
I know how to unbolt it :rolleyes: The issue is that it seems way longer than the space available to pull it out. I figured someone here may have taken one out and had a tip or trick or even just a "It'll come out in the space available." I guess I will see.
8,745
Only the first line was being a class clown,
The rest was solid advice, sorry you didn't get that.
If it won't spin up then yes just pull the dynamo out of the way.
